I have Unreal Engine 4.26 and Houdini 18.5.532 Indie. When I try to start a session between Unreal Engine and Houdini, I get
"Houdini Engine Session FAILED - No License" message. The Houdini plugin is installed. How can I fix the problem?
9414 3 1- jeffmorris
- 18 posts
- rafalmeida20
what's up dude. watch this video if you're still having trouble.
https://youtu.be/XYmVoJ3waLc [youtu.be]
- mwstandsfor
Issue I have is that in UE4 houdini unreal engine license works but in UE5 it doesn't
I use the same plugin settings in UE4 and UE5, both pointing to the same HDA. Session starts with no problem, but then when I add the HDA to the scene in UE5 the output reads:
"License failed: Disallowed Non Commercial License found."
I've downloaded the same plugin repository from github (https://github.com/sideeffects/HoudiniEngineForUnreal-v2/releases)
HoudiniEngine-v2.0.3-H18.5.633-UE4.24.zip for UE4 and
HoudiniEngine-v2.0.3-H18.5.633-UE5.00EA2.zip for UE5
- OgnyanTsonkov
- 3 posts
