Hello, I've been working on an RBD simulation on an animated human object, but I'm having a problem blending between the animating geometry and the active simulation. Since it did not work in a SOP Solver, I tried using a Solver outside of the DOP in order to manually update the @deforming and @active attributes. However, that did not work either. I'm wondering if there was an issue in the way I was packing the geometry, or maybe in the way I was assigning the attributes. I would really appreciate your help. Thank you!
Since the file was too large, I'm sharing the link where you can download the file.
https://drive.google.com/file/d/1Cs8SbuiUx_Kl7CJKTK6X1JQP7_N8a0e5/view [drive.google.com]
RBD simulation on an animated object
5551 3 1-
- kdy7991
- 3 posts
- OvidiuChiriac
- 4 posts
- npetit
- 430 posts
- OvidiuChiriac
- 4 posts
Hello , my name is Ovidiu, i am FX Artist in Houdini FX, i have a big issue with one animated car, explosion behavior of the car, and one static glass geo, i wish to atach the static glass geo to the animatde car and shatered like one explosion with good constrints , and in the end after the animation of tha car is finish and explosion of tha glass is shatter the glass some few parts of tha glass to stay glued of the body car. I atached the hip file with the animation of the car and the glsss geo, and with some setups for the constraints and rbd , i dont understand wy the glass is not staying of the animation of the car glued. even i create the car as rbd deformed the constraints is not available. Maybe is a simple adjustments but i dont figure out yet were i doing somehing wrong. Can you help me with this one? I atach Alembic of the car anmation and the static Glass is locked in Hip file.
Tanks,
Good Day,
Ovidiu.
Alembic of the Car: https://mab.to/FYwc11jFt [mab.to]
In case that link from my air bridge expire , dropbox: https://www.dropbox.com/s/u0x5ju5kq2fk40u/Car_Destruction_anim_v04.abc?dl=0 [www.dropbox.com]
Tanks,
Good Day,
Ovidiu.
Edited by OvidiuChiriac - Sept. 16, 2021 14:35:53
