Hqueue problem with a windows and linux renderfarm
   1355   1   1
We have set up a renderfarm managed by Hqueue with Windows and Linux stations.
On all these stations we have installed Houdini and I would like to know what to put as parameters in Target HFS so that Hqueue uses the version of Houdini that we have installed?
When we put $ HFS it works fine under windows (our workstations are under windows) in renu and simulation but not on Linux.
What must be done also to be able to use the projects which are on a NAS without being accessible on Windows through a network drive but on Linux we use UNC which we cannot do on WIndows
our working tsations are in Windows 10 with Houdini 18.0.532
and our render in windows 10 and centos 7 or 8 with Houdini 18.0.532.
Thank you in advance for your assistance.
Hi, there is a bit of information here from a sidefx staff member about configuration of mixed linux and windows/UNC hqueue:
https://www.sidefx.com/forum/topic/51988/?page=1#post-234276 [www.sidefx.com]
You might consider emailing sidefx support directly, forum replies might be a bit random. Support was very good when I had trouble setting up the first time.
