IMPORTING AN ANIMATED MODEL
   7077   6   1
hello I have a model that I have animated in motion builder, I would like to import it into houdini to use to drive particle system. please help me, OBJ will no be animated.
If you can export the animated geometry as a Wavefront OBJ file sequence, you can then use a File SOP to load them into Houdini.
In Houdini 8.1, you can use Collada Import [sidefx.com] so if you can export to a Collada file format through Motion Builder, that will work too.
Cheers!
steven
i try to export an OBJ but it is just the model. I do not know how to make it animated
as stevenong mentioned, you have to export every frame of the animation as .obj file. ( name.$F4.obj)
load the sequence into houdini: file sop-> name.$F4.obj
Michael Fuchs -|- Owner Sparkling Design -|- Austria
Sparkling Design [sparkling-design.com]
There are MEL scripts around (odforce.net?) that will dump out a series of animating frames from Maya to obj files (one for each frame).
-Craig
Does Collada import properly handle all the joint to bone translations and skinning and motion curves and maintain everything?
Or is it baking things?
-Craig
I think it imports keyframes.
