An antivirus that doesn't mess with Houdini.
9196 15 3- jamesbeylik@yahoo.com
- 6 posts
- JColdrick
- 4140 posts
- Allegro
- 696 posts
- wolfwood
- 4271 posts
- varomix
- 460 posts
I totally forgot about that, linux made my life way easier in a lot of ways.
although our 2D animation dept. still uses XP, we found a very nice solution, AVG, works great and keeps the viruses out, is not free but is actually useful
good luck
and yes it leaves houdini do its tricks
good luck
varomix - Founder | Educator @ Mix Training
Technical Artist @ Meta Reality Labs
- digitallysane
- 1192 posts
- splitpoint
- 57 posts
- 6 posts
Thanks guys.
Antivirus refers to software that protects your computer from viruses, trojans and soforth. I'm surprised that you use Houdini and have never heard of that. It's old hip slang, and yes I'm quite hip.
Anyway, Norten and Panda seems to make Houdini render white shapes and applying shaders is impossible.
So I'll try Avast and some of the others. Thanks.
James Beylik
- JColdrick
- 4140 posts
I think you'll find the comment was being sarcastic. If you read all of the other responses, you'll see quite readily that *no-one* is having troubles you're assuming to be universal. You can switch around products if you want, but the problem simply doesn't happen with those products. I suspect they need proper configuration.
J.C.
J.C.
John Coldrick
- wolfwood
- 4271 posts
- moonlightkiss
- 156 posts
You might actually be having a permissions problem. We experienced a problem at the school I teach at, where basically the shaders had no parameters and all the objects were rendering white. Basically Houdini needs to be able to write and access the folders it installs to or else shit hits the fan. All I know is that when they unlocked the computers so non-admins had complete permissions the problem went away.
had nothing to do with the ant-client virus thingger you youngins are talking aboot.
“In the beginning the Universe was created. This has made a lot of people very angry and has been widely regarded as a bad move.” - Douglas Adams
- svenvfx
- 13 posts
- Jonathan de Blok
- 274 posts
- Allegro
- 696 posts
- bobc4d
- 327 posts
- Alex Amos
- 28 posts
I've moved over to Kaspersky Security Cloud (free).
It's extremely lightweight, I can scan in the background and not even notice anything happening on my machine, which was not the case with Bitdefender (free) and many others I had tried previously. I ended on Kaspersky Security Cloud after doing research for the most lightweight AV.
Seems to work really well so far.
