Hi
Is Example for control pdg from hython?
I dont know how get pdg.node for cook.
PDG hython
5936 9 5- X_H_N
- 31 posts
- BrookeA
- 387 posts
- X_H_N
- 31 posts
- chrisgreb
- 603 posts
- shadesoforange
- 201 posts
Hey chris,
could this command theoretically be sent as a job to basically have a graph execution as job?
Manuel Köster - Senior Technical Artist @Remedy Entertainment
https://www.remedygames.com/ [www.remedygames.com]
http://shadesoforange.de/ [shadesoforange.de]
https://twitter.com/ShadesOfOrange_ [twitter.com]
- chrisgreb
- 603 posts
- shadesoforange
- 201 posts
Thanks Chris!
Is there a reason why that doesn't exist on the DL scheduler? If yes, why?
- seelan
- 571 posts
- shadesoforange
- 201 posts
Awesome! Sorry to interrupt this topic.
- papsphilip
- 385 posts
Is there a way from PDG to force a SOP node to cook?
A have a python node that takes geo and exports a txt file. All this in SOP land
When i use a filepattern TOP node to collect my geo from folder and a wedge to control some parameters of the graph that ultimately ends with the python node, i cook it and nothing happens.
i need to select a work item and the python node gets evaluated.
Why is this happening and how can i force sop nodes to cook from tops when i am not using TOP nodes for exporting geo or images but my exports are being done in SOPs. I just need the PDG graph to iterate through my 3d models apply some wedges and let the python sop do its thing.
Apart from the python node i have some other nodes as well that export stuff (Houdini to Unity Volume-point cache exporter). i have the same problem with those.
Any advice would be super helpful
