Multi object output
5400 8 1- Gand
- 23 posts
- anthonyt2
- 100 posts
- moferad
- 19 posts
I'm also having this issue , but on the latest daily of Houdini 19.0.425
Im also on the updated unity houdini engine package from the same installation , only difference is that im not actually getting a second output with my version compared to Gand
I saw your commit here https://github.com/sideeffects/HoudiniEngineForUnity/commit/171f121da8d2064ac3b6711156bbc098d03b8179 [github.com]
Thanks for keeping the plugin up to date Anthony! hoping we can help figure out some bugs, im going to test this in 18.5.749
UPDATE: Confirmed not to be working in 18.5.749 either, Only getting one output
Edited by moferad - Nov. 2, 2021 22:57:14
- moferad
- 19 posts
Interesting, I might have found another problem, I noticed recooking is not actually updating the asset, and I have to forcefully "restart session" and recook again to see any change happen, not sure if this is related , this is happening on 18.5.749
added a video
added a video
Edited by moferad - Nov. 2, 2021 23:40:56
- anthonyt2
- 100 posts
Hi, I have identified several issues regarding geometry outputs after the "output node" change. See https://www.sidefx.com/forum/topic/81539/ [www.sidefx.com] for more details. It should be fixed in 18.5.753/19.0.430.
- moferad
- 19 posts
Thanks @Anthonyt2
Ive grabbed latest and wiped my old plugins folder for the new package in 19.0.430 , unfortunately im still seeing a problem with the multioutput
The image below shows that it still is not outputting the second outputs, am I doing something wrong?
The second image shows that by setting split by groups I get both results out of my hda, although its odd because it needs to be set in the plugin settings , the "split geo by groups" toggle in the hda itself does not do anything
- anthonyt2
- 100 posts
- Edwin88
- 5 posts
- anthonyt2
- 100 posts
Edwin88
Hi ! I am using the new option "Use output nodes" in my .hda wich works well. But when I bake it into a game object, I loose all my separate nodes, it result one game object. Is it possible to keep multiple output when I bake it ?
Thanks !
This looks like something we must have overlooked. I'll mark this as a RFE. For now, you can try just dragging the outputs out manually.
Edited by anthonyt2 - Dec. 13, 2021 10:54:01
