How import VDB into houdini?
   5252   9   0
I have VDB-sequence, created in other soft. And can`t import it into houdini. Need example of node-system.
For importing into SOPs use a File sop.
For Solaris, use a volume LOP.
jsmack
OK. What i doing wrong? How i should reposition nodes?
Edited by petr.chel - Nov. 8, 2021 13:39:17
Скриншот 08-11-2021 213701.jpg (34.9 KB)
delete the vdb sop
jsmack
delete the vdb sop
ok. Delete, but nothing changes. Scene is empty/
Edited by petr.chel - Nov. 8, 2021 21:48:43
Скриншот 09-11-2021 054705.jpg (164.9 KB)
I would try to plug your file node into a primitive node and modify the volume display mode
I resolve it. Was need on stage of create VDB to do export with many parameters. Temperature, density, fuel and other...
petr.chel
How about you learn a bit of Houdini first.
When you have a vdb sequence just a file sop should be enough, middle mouse click on the node shows you all volumes imported
http://www.sekowfx.com [www.sekowfx.com]
hi i have downloaded openVDB and cannot seem to load it into houdini could someone please provide me with a way to do this asap!!
thank you so much.
https://www.sidefx.com/forum/topic/81580/#post-351400 [www.sidefx.com]
additionally you can also do File/Import/Geometry...
Edited by tamte - April 4, 2024 13:14:52
