Converting USD Preview Shader from Maya to MaterialX?
   8920   13   2
I have an asset that had look-development performed in Maya using Substance painter and Arnold shaders.
This was exported to a USD file with USD preview shader option selected, using the Maya "official" USD plugin.
I imported this into Houdini 19 Solaris.
Unfortunately, the preview shaders don't look like they import correctly. Only one of the texture maps is mapped to emission.
Is there a procedural way to re-map the preview shader to a MaterialX surface shader?
e.g. with variants?
Any guidance would be appreciated, as manually remapping multiple shaders would be onerous.
Edited by syntheticperson - Dec. 20, 2021 13:31:38
Screen Shot 2021-12-20 at 10.23.34 AM.png (356.7 KB)
Screen Shot 2021-12-20 at 10.23.46 AM.png (215.8 KB)
Screen Shot 2021-12-20 at 10.23.54 AM.png (2.8 MB)
Your export is broken. It's missing the shader part of the material. The example has the texture reader connected directly to the surface shader output of the material. There should be a USDPreview material in there between the textures and the material output.
jsmack
Then that means Maya 2022 USD export is broken. I'll post to the Maya/USD forum to see if there is a fix on their end.
Even if I get that working, I still need to find a way to mass convert multiple USD preview shaders to MaterialX.
syntheticperson
I'm not sure what you mean by convert to mtlx. Do you mean save the materials from the usd as mtlx files, or replace the usdpreview nodes with mtlxusdpreview nodes?
jsmack
syntheticperson
Sorry. My goal is to export USD from Maya/Arnold such that I end up with MaterialX materials in Houdini 19/Solaris.
i.e. I want all the substance painter textures that work with Maya/Arnold, to port across to Solaris via USD, re-map to MaterialX, and work with Karma.
Edited by syntheticperson - Dec. 21, 2021 00:21:48
I'm assuming the plugin translates hypershade nodes into Mtlx networks?
jason_iversen
The Maya USD plugin supports USD Preview Surface, RfM Shaders, Arnold Shaders, and RenderMan for Maya.
Whereas, Arnold for Maya has its own USD export menu.
Since Arnold for Maya supports Material X, that might be an option. However, it means converting all the Arnold standard surfaces to Material X on the Maya side, then re-exporting to USD. Which is less than ideal.
So it turns out the Arnold plugin for Maya does allow you to export selected geometry materials to Material X. Unfortunately, it is a flavor of Material X specific to the Arnold renderer.
If you have the Arnold Renderer plugin installed in Houdini, you can then import the materials into Houdini.
My goal is to convert them to Houdini/Karma-compatible Material X.
It looks like I'm going to have to bite the bullet and convert them.
Any ideas on how one would go about doing this with Solaris LOPS or python?
Screen Shot 2021-12-28 at 11.05.21 AM.png (1.7 MB)
syntheticperson
Sad, as that defeats the point of MaterialX. Are Autodesk able to supply a way to convert to standard MtlX?
jason_iversen
syntheticperson
Not that I know of.
In the meantime, I have figured out how to convert Maya Arnold standard surface Material X to Houdini/Karma Material X standard surface. i.e. the python code snippets for each step.
I'm about 3/4 of the way through completing a Houdini 19 HDA which semi-automates this process.
I'm doing this out of necessity. I have assets that were look-dev-ed in Maya Arnold, and I want them in Houdni 19 Material X.
If there is interest, I will open-source the HDA when I get it working.
syntheticperson
Yep, understood completely.
I see from https://docs.arnoldrenderer.com/display/A5AFMUG/MaterialX [docs.arnoldrenderer.com] that it's a bit of a mess where there are nodedef extensions and special conditions/etc: no doubt designed to support 1:1 translation of arnold materials to it's mtlx input interface, as well as support reading standard mtlx nodes. They appear unconcerned about using MtlX as an interchange format.
jason_iversen
syntheticperson
Yeah, Arnold Material X is cross-platform in the sense that it will work with the Arnold renderer across supported DCCs.
e.g. Maya, Houdini, etc. However, I feel it falls short of the vision of Pixar's Universal Scene Description vision, and ILM's Material X; platform-independent description and exchange across applications and renderers.
syntheticperson
jason_iversen
syntheticperson
Not that I know of.
I would really love a converter as well. Sadly, I am not so good with python
https://www.youtube.com/channel/UC4NQi8wpYUbR9wLolfHrZVA [www.youtube.com]
Hey, just found this on google as I’m going through the exact same problem. Did you get anywhere with the converter? Happy to join in the effort. I think it’d he huge help for many who want to get out of Arnold and into karma! Got some devs who could lend a hand too.
