Image sequence as any material texture channel (diffuse, emission, opacity) in h.19 - are broken in viewport. Blinked, lost frames and transparency.
Also background texture do not work if i try use image sequence instead of still.
Try *.rat, *.pic and *.png - same result.
18.5.* - same scene and same image sequence work fine.
H.19 viewport texture issue, with image sequence.
4372 11 3- Dronson
- 47 posts
- Tobias_SFX
- 6 posts
Dronson
Would you mind posting your project file? I'd be happy to take a look at it.
- Dronson
- 47 posts
Tobias_SFXDronson
Thankyou for answer Tobias. I cant post project file - under NDA. May be similar exemple ?
- sekow
- 238 posts
- Tobias_SFX
- 6 posts
DronsonTobias_SFXDronson
If you have a similar example that would suffice. Also, please indicate your system specs. Thank you kindly.
Edited by Tobias_SFX - Dec. 17, 2021 15:55:22
- julca
- 219 posts
Also noticed this blinked problem on viewport with images sequence and posted to support at the beginning of december with a simple project to reproduce.
They say that they see the problem and they logged this issue in their database : Bug (ID# 117942)
Perhaps this will be fixed between two pieces of Christmas log.
- wd
- 7 posts
- Dronson
- 47 posts
- julca
- 219 posts
- Dronson
- 47 posts
- Dronson
- 47 posts
- wd
- 7 posts
