Hey!
I have an issue here with Karma renderer, it's just not works here.. I've checked Apprentice restriction list and looks like all should be fine and work.
Maybe you could help me?
Here is some info:
Karma render delegate failed
4785 7 2-
- mclawest
- 5 posts
- 8127 posts
- mclawest
- 5 posts
- VahMG
- 4 posts
- duveil
- 20 posts
- mclawest
- 5 posts
- duveil
- 20 posts
mclawest
any info from your console log would be helpful
Hi thanks for quick answer. I installed 589 version first but I got
munmap_chunk(): invalid pointer Aborted (core dumped)
error then I used export LD_PRELOAD="/usr/lib64/libc_malloc_debug.so.0"
code for that and it worked but karma gave render delegate error. Now I dont have any idea where to
look.
[mustafa@fedora ~]$ houdini Houdini DSO error on '/opt/hfs19.0.619/houdini/dso/SOP_Substance.so' libGLU.so.1: cannot open shared object file: No such file or directory [mustafa@fedora ~]$ Unable to create Usd Render Plugin: HD_HoudiniRendererPlugin HD_HoudiniRendererPlugin not supported - removing from renderer list Houdini DSO error on '/opt/hfs19.0.619/houdini/dso/usdui/USD_UI.so' libGLU.so.1: cannot open shared object file: No such file or directory Unable to load DSO /opt/hfs19.0.619/houdini/dso/usdui/USD_UI.so System configuration error. Try running with HOUDINI_DSO_ERROR=1
Edited by duveil - May 16, 2022 15:40:30
- duveil
- 20 posts
