Is there a way in Mantra to render an output both to Mplay and to a specified File at the same time?
I sort of want to be able to see the render progress of an image while it is rendering. Then after it is done, it writes it out to a file that I've set automatically.
Render to MPLAY+FILE
10433 9 2-
- galagast
- 265 posts
- caesar
- 143 posts
- galagast
- 265 posts
Hi Ceasar, thank you for the response. I'm quite aware of the option to manually save the image after it renders
What I was looking for was a way to have it done automatically, MPLAY render + Save.
Initially I thought that I could just enter an output path and “ip” to the Output Picture on Mantra like in the attached image, but that doesn't work
I even tried using various separators like “;” “:” “|” etc..
I suppose what I was hoping for was to be able to leave Houdini rendering (locally or even on a farm), then be able to view an MPlay preview of the current render progress simultaneously, it does not even have to retain the whole sequence in memory. Sort of like enabling the Frame Buffer window in 3dsmax during rendering.
Right now, Houdini only seems to let you choose between Render to Disk or Render to MPlay.. but not both.
If this is currently impossible, I could probably send an RFE. But I just wanted to first confirm here if there was a way to actually do it.
- niko3d
- 338 posts
- galagast
- 265 posts
Updating this thread as a somewhat related new feature in H16.5 was added.
Flipbook now allows to MPlay and save to disk at the same time.
But this one is only for doing Flipbooks. Hopefully some option of similar nature could also be added for Mantra's Render to Mplay.
RFE ID=86319
RFE ID=86319
Edited by galagast - Nov. 8, 2017 11:08:28
- cgbeige
- 99 posts
- Grendizer
- 375 posts
- xyzDist
- 11 posts
- xopowoo
- 28 posts
- 8127 posts
