I am trying to figure out why the top of the liquid is darker than the bottom. I tried every setting I could think of and I'm unable to have a consistent color between the outside of the liquid and its inside. I played with the at distance but it does not help, when I increase the distance, the bottom of the liquid becomes darker and the top of the liquid becomes lighter.
IOR of glass is 1.5
IOR of water is 1.33
I also made sure the water is slightly overlapping with glass.
Any help would be much apprecicated!
I'm running Houdini 19.5.533
Nested dialectics with Karma
2273 4 1- jd_m_007
- 18 posts
- protozoan
- 1718 posts
Nested dielectrics are currently unsupported in both regular Karma and KarmaXPU.
For reference, check this comparison table (need to scroll down a bit): https://www.sidefx.com/faq/karma/ [www.sidefx.com]
But I'm not even sure this is the problem in your case, it may be simply too low of a refraction depth (this defaults to 4 now, it was 10 on mantra ROPs).
Martin Winkler
money man at Alarmstart Germany
- jd_m_007
- 18 posts
I have set the refraction and reflection limit to 16 but it does not help, I get the same result.
protozoan
- 8833 posts
- jd_m_007
- 18 posts
