Hi. I'm trying to use the Clip SOP to divide my geometry. I want this geometry to divide facing the camera so I'll have separate planes of my geometry facing the camera one at a time. Like plane one will be closest to the camera, plane two will be right behind, plane three will be behind that, etc. Does anyone know how I might be able to do this?
There is an option to change the clip direction but I'd just be eyeballing it. I'd hope there's a way to pull the camera direction and place it in the clip direction boxes. I'm a vex newbie so maybe there's something that would work with that but everything I've tried is either breaking or it doesn't do what I want it to do.
Clipping SOP in camera direction
1836 4 2- ClamsDown
- 8 posts
- animatrix_
- 4729 posts
I wouldn't bother with the Clip SOP. It's much easier and faster to generate a center line for the camera with a given number of points and use it with Voronoi Split SOP to split your geometry at once into multiple parts.
You can use VEX to do this in a Detail Wrangle:
Then I resample it using this expression for Segments:
If you want uneven splitting, you can even shift the positions of the points using a ramp parameter.
string cam = chs("cam"); float near = -ch("near") - 0.0000001; float far = -ch("far"); vector pnear = fromNDC ( cam, set ( 0.5, 0.5, near ) ); vector pfar = fromNDC ( cam, set ( 0.5, 0.5, far ) ); vector dir = normalize ( pfar - pnear ); pnear += dir * ch("s") * 0.5; pfar -= dir * ch("s") * 0.5; addpoint ( 0, pnear ); addpoint ( 0, pfar ); addprim ( geoself ( ), "polyline", 0, 1 );
ch("../create_center_line/zones") - 1
- 8043 posts
animatrix_
Doesn't that split on the half way point between points? That sounds unintuitive and difficult to control without doing a bunch of math. The OP said they didn't want to use VEX. The old dumb slow clip is easier to 'see' how it works.
To get the clip direction from the camera, no vex is needed.
Right click origin parameter and select "Reference->Scene Data". Then find the camera and select Translate under Transforms->World. Right click a direction axis parameter and select "Reference->Scene Data" again. Find the camera and select Direction -> -Z. This will fill in the three axis parameters with the reference to the camera's world Z direction. Then adjust distance to set the clipping plane distance.
- ClamsDown
- 8 posts
animatrix_Thanks very much for this! I'm not trying to stay away from VEX per-se but I would like to be able to figure stuff out and learn rather than copy-pasting someone else's work. Thanks so much for this and I'll be looking at this code to try and decipher what you've done here.
You can use VEX to do this in a Detail Wrangle:string cam = chs("cam"); float near = -ch("near") - 0.0000001; float far = -ch("far"); vector pnear = fromNDC ( cam, set ( 0.5, 0.5, near ) ); vector pfar = fromNDC ( cam, set ( 0.5, 0.5, far ) ); vector dir = normalize ( pfar - pnear ); pnear += dir * ch("s") * 0.5; pfar -= dir * ch("s") * 0.5; addpoint ( 0, pnear ); addpoint ( 0, pfar ); addprim ( geoself ( ), "polyline", 0, 1 );
Then I resample it using this expression for Segments:ch("../create_center_line/zones") - 1
- ClamsDown
- 8 posts
jsmackanimatrix_
This is exactly what I was looking for! Yeah... It's a bit of math and manual bananas on my end with this method but I'm still learning. This referencing scene data is great! I can do so much with this!!
