Intro to crowds 19.5 issue fix compendium
   2209   2   1
Issue with usd rendering out only a single frame -> Cook Frames as Single Work Item in ROP uSD in tops.
agent does not exist error when inplace animation turned on -> point to hips!
Edited by NicTanghe - Nov. 6, 2022 09:39:27
5.1_io_usd_Nic_v1.hiplc (1.3 MB)
USD_crowd.walk.usd (747.3 KB)
USD_crowd.run.usd (747.4 KB)
I think you might want to have `Cook Frames as Single Work Item` on, since you want to generate a single USD file with the time samples from the whole frame range?
That seems to have worked.
I needed to restart houdini to clear casehs first though.
Edited by NicTanghe - Nov. 6, 2022 07:30:52
