Point deform a find shortest path on a deforming mesh
   1490   4   1
I have a findshortest path between points on a mesh, I want the path to deform (stick) to its deforming mesh (same polycount as its a vellum ballom)
any ideas?
many many thanks!
here is the file example...
i want the findshortest path to stick to the vellum object without recomputing each frame... any ideas? thank you so so much.
FindShortest_path_OnVellum.hiplc (559.3 KB)
Hello, a point deform should do the trick.
FindShortest_path_OnVellum_pointdeform.hiplc (570.9 KB)
YOU ABSOLUTE STAR!!!!!! thank you thank you thank you!!!!
You don't need to point deform, you can just attrib copy using origpt point attribute created before the sim:
