KineFX Masterclass | Houdini Illume | Jeff Wagner | 23.06.2021
   Views 15318   Replies 4   Subscribers 5
- watched the Video from Jeff Wagner
Your text to link here... [www.youtube.com]
at 21:57 he talks about motionclip blend
in my Testscene the Arms get scaled down ?
any Tips n that
the Stash Nodes are only for easy vewing the scene
- so you dont have to download the fbx files
Edited by w_maro - May 17, 2022 03:00:18
KineFX-Rigging_01a-motionclipblend.hiplc (355.3 KB)
OK - it worked with a Skeletonblend
but in the Video this should also work with only the motionclipblend ?
w_maro
any Tips n that
xss.html (29 bytes)
Hello guys, I have the very same problem except in my file the arms become absolutely microscopic (very sweet like a baby squirrel but not what I need).
If I scale the effect of motionclipblend down to zero the arms keep their reasonable size, but of course I need the effect. And if I swap the inputs the arms get monstrously big.
EDIT: Within the motionclipblend asset there's computetransform2 in the foreach-block. This is where the arms shrink that much. But I assume the reason is somewhere in one of the transform attributes that still exist before the motionclipblend.
Do you have any idea what might be wrong here?
Edited by freewind - Feb. 5, 2023 21:29:34
Intel core i7 6700K
64 GB DDR4 RAM
Nvidia GeForce RTX 3060
So I found out I can not delete the joints I want to blend as Jeff does it in the tutorial, cause everything from the first missing joint in the hierarchy gets some messed up transformation data.
A way that worked in my scene instead is choosing the joints to blend in the motionclipblend Group parameter. That way no data needed is lost.
Intel core i7 6700K
64 GB DDR4 RAM
