Hi,when use sublayer or merge node to merge to usd file together.the two usd can be composited,and the second usd's attributes will override the first one.
is there a way to chose any attributes or any objects to override but not everything?
I whish my explanation is clear.for example there are a.usd and b.usd,both have /geo1 and /geo2 objects,they have different transform and materials from a.usd and b.usd.
when I merge b.usd over a.usd,is it possiable to keep /geo1's transform from a.usd, and use /geo2's material from b.usd?
is there a way to override part of attributes?
1709 5 0- luoqiulin
- 306 posts
- antc
- 337 posts
- elovikov
- 130 posts
I think in this case you can block properties on Edit Properties LOP. You just need to do that before you bring a sublayer. Check the minimal example in the attachement.
Edit: well, it's not quite working, it just resets property to default value on resolution. Interesting, intuitively I thought it just skip it
Edited by elovikov - May 9, 2023 13:55:42
- luoqiulin
- 306 posts
- mtucker
- 4525 posts
- elovikov
- 130 posts
