hi all, is there any way to hide the node wire connection.
I'm coming from nuke and trying to replicate Postage stamp feature in Houdini.
Thanks in advance!
Hiding the node wires
1326 3 1- lukexhoudini
- 3 posts
- lukexhoudini
- 3 posts
- Mohanpugaz
- 146 posts
Yes you are right, Object merge is what you are looking for. One more quick tip. In network editor If you go to view > enable dependencies For selected. Then you can see a brown wire for selected node which shows connection from object merge to your source node. It will be handy to keep it enabled.
Hope that helps π
Hope that helps π
Mohan Pugaz
movfx
movfx
- lukexhoudini
- 3 posts
