Adding Objects in Path using Primwrangle
1312 5 1- vipinfx
- 4 posts
- olivierth
- 1075 posts
- vipinfx
- 4 posts
olivierth
I would go like this:if(find(s@name, "sphere") >= 0){ // if it finds the word sphere, it will give a number above zero s@path = "/shop/assets/Sphere"; }
Thanks for the reply olivierth , the result is same for me.. its merging anything that names sphere in to one object mesh instead of adding them individually on the xform
- Mohanpugaz
- 146 posts
to avoid merging, you would need to add the existing @name to the path
if(@name ~= "sphere*"){ s@path = concat("/shop/assets/Sphere/",s@name); }
Edited by Mohanpugaz - July 6, 2023 03:53:57
Mohan Pugaz
movfx
movfx
- Mohanpugaz
- 146 posts
If you have multiple objects in each of the categories then you could set it up like this
Also attached .hiplc file if you wanna take a look
Mohan Pugaz
movfx
movfx
- vipinfx
- 4 posts
