SideFX labs nodes are only available if I delete the Redshift related variables in my houdini.env
What can I do to circumvent this and have both SideFX Labs and Redshift work?
SideFX Labs conflict with Redshift houdini.env, in 19.5.569
2013 7 3-
- cheesetroyer
- 52 posts
- toadstorm
- 360 posts
Sounds like your environment isn't configured correctly. Can you post the contents of it here?
- cheesetroyer
- 52 posts
- cheesetroyer
- 52 posts
I'm sorry I guess the issue was not resolved.
I had created two houdini.env files, one for Redshift and one for Renderman, since I had problems getting them both to work.
And I must have confused them.
# NOTE: The use of packages is highly recommended instead of houdini.env
# See details about packages here: https://www.sidefx.com/docs/houdini19.5/ref/plugins.html [www.sidefx.com]
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
# VAR = VALUE
# Values may be quoted
# VAR = "VALUE"
# Values may be empty
# VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
HOUDINI_PATH = C:/CitySampleSource/Small_City/houdini;&
HOUDINI_USE_HFS_OCL = 0
HOUDINI_DSO_ERROR = 2
PATH = "C:/ProgramData/Redshift/bin;$PATH"
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/19.5.569;&"
PXR_PLUGINPATH_NAME = "C:/ProgramData/Redshift/Plugin/Solaris/19.5.569"
OCIO = "C:/ProgramData/redshift/Data/OCIO/config.ocio"
# the environment.
# VAR = VALUE
# VAR = "VALUE"
# VAR =
# Example:
- toadstorm
- 360 posts
You can't create separate env files and use them at the same time... you have to either combine them into one file, or use packages (the recommended route).
The reason your env file isn't working is because you're defining HOUDINI_PATH twice, and not including $HOUDINI_PATH within the second definition (which would append any new paths to the original HOUDINI_PATH). Try something like this:
HOUDINI_PATH = "C:/CitySampleSource/Small_City/houdini"
HOUDINI_PATH = "$HOUDINI_PATH;C:/ProgramData/Redshift/Plugins/Houdini/19.5.569;&"
Packages are a much better option once you get used to JSON syntax. Here's an article [www.toadstorm.com] about them.
- cheesetroyer
- 52 posts
- Mohanpugaz
- 146 posts
I have made two video tuts on how to install redshift and sidefx labs using the packages method, they work fine without any conflict. you can try them if you want.
Mohan Pugaz
movfx
movfx
- cheesetroyer
- 52 posts
