How can I extend the duration of ChopNet?
Thanks for your help!
Simon Russell
if you look under the channel tabs, set the sample rate to your fps and set the channel length as long as you need it... it should fix it. look in your motion channels viewer to see what you're doing
巴巴杰
If you're going to be going back and forth between changing frame rates you have to decide whether or not you want to keep the keyframes at the same frames with the 'Keep Keys on Current Frames' option.
But you also have to go back to your chops objects and adjust the start/end range too.
HenDaSheng
Thanks, I tried modifying the options here, but it still doesn't work.
BabaJHenDaSheng
You didn't change the start/end range of your objects.
Bring up your motionfx window and enable the objects view to see where they are established; From which ever way you decided to have them set up by.(works for me if I manually adjust the range).
HenDaShengI'm using your file, there is no modification other than what is in the sreen shot.
Thanks a lot for your help, can I have a look at your modified houdini file, I'm very new to Motion Fx.
巴巴杰HenDaShengI'm using your file, there is no modification other than what is in the sreen shot.
Just bring up your motionfx window and make sure the object2/3 nodes have there flags set(blue)- so it shows up in your graph.
