Scatter points on surface with falloff density near the edge
4220 5 1-
- artmklgnv
- Aizatulin
- 496 posts
you can use the xyzdist() function to measure the shortest distance from any point of the surface to the border. After this you can use a ramp for example to set the @density attribute, which can be used in the scatter node. Make sure that you have enough surface points (for scatter).
Edited by Aizatulin - July 8, 2019 13:24:28
- Andr
- 899 posts
Maybe less efficient than Aizatulin's solution, but a code-less approach is to use a falloff node.
Have a look at the example file (play with the parms in the colored node to change the effect)
Also, a more exotic approach would be creating the density map in a cop network.
Import your shape with a geometry node and try to shrink and blur it with some filters.
I tried a bit, with no much luck, the shrink/expand cop node seems buggy.
It would interesting to see it implemented..
cheers
cheers
- NicTanghe
- 216 posts
- animatrix_
- 4769 posts
NicTanghe
Annyone know how to do this with volumes ?
If you have an SDF, you can use it to remap density using a ramp:
float density = fit ( @surface, ch("min"), ch("max"), 0, 1 ); @density = chramp("density", density);
- BillTarner
- 3 posts
