Houdini 20 will be unveiled (not released) on October 26
   30867   128   5
GCharb
You don't create shader networks in Houdini, you work with shader nodes, you can drag and drop images/movies in shader nodes texture slots no problems!
dropping an image file into shader network of blender automatically assigns a required node. no additional steps-substeps-whatever. super handy and fast, for iterative approach it's the way
also, "You don't create shader networks in Houdini" - how are you even shading then...
anyway - movie files dont work all the same. requires some mumbo jumbo explained elsewhere on forums (it was about animated image sequence, no idea if it will even work with .mp4 or .mov) - with virtual production on the rise this is so whacky to not "just work"
thankfully i am doing this ^ in UE nowadays, but the point remains
Edited by osong - Oct. 26, 2023 01:25:07
https://twitter.com/oossoonngg [twitter.com]
SO anyone have been in Soho yesterday on key-note. Or it is just theoretical thread with just guesses?
When I work with the Type Properties Window and I find myself screaming each time I have to resize some inner section, where should I direct my rage, at the bad UI or the bad UX?
I mostly scream using houdini, 15 years in and I scream more now than in the beginning.
I did a breakdown of the UX/UI tool<->selection switching-pattern once when trying to implement a custom python state. Wish i still had the flowgraph around (was whiteboarded only). but it was a total mess. I compared it with Blenders pattern and lo and behold, no wierd and complex intermediate pathways through multiple states with changing tool panels and overlapping hotkeys.
There are core parts on houdini with flat out bad design patterns…
B-System for Houdini [ae43ae43.gumroad.com]: instance editor, blender like interface.
Frankly there are issues with all software, OS and also hardware. Nothing can be a swiss knife. Use what works and post-pone or skip what does not work for your case.
There is something called a SWOT analysis, maybe try that for a change to get a bigger picture.
Enjoy the coffee!
Edit: If you really want a change maybe bring some proposals, i.e. some prototypes that are possible to implement.
Edited by SWest - Oct. 26, 2023 03:55:11
lol yeah, i should just redesign the houdini selection pattern and submit it as a RFE. thanks for the advice
making prototypes and proposals on unpaid basis
what could possibly go wrong
osong
GCharb
Again, you do shading by assigning a shader node to the 3d model, there is no shading network like in Blender, there are no nodes that needs to be assigned, it's all within the shader node, and yes, movies work if you put them in a texture slot, have you ever shaded anything in Houdini? 🤔
Edited by GCharb - Oct. 26, 2023 06:28:50
principled shader textures.jpg (109.0 KB)
GCharb
uhhh... what? 🫥 have you not seen shading network in blender? in Houdini?
this is my screenshot of blender network
this is my screenshot of solaris material network
GCharb
why i am glad you've asked, i have the highest rated Mantra videos on the youtubes
BTW, you inserted the old principled shader in the Solaris space, it will not evaluate in XPU 👍
Edited by osong - Oct. 26, 2023 11:37:13
Houdini Fan Club is so sweet
alexeyvanzhula.gumroad.com
osong
We're talking about textures here, and those are usually assigned inside the shader nodes, not in a network, but you could use them in a network if you wanted, I just don't see the use, so my guess is that your original complaint is about not being able to drag and drop textures in the VEX builder, is that it, and the old Principled shader works just fine in XPU here!
Edited by GCharb - Oct. 26, 2023 07:23:16
principled shader textures 2.jpg (592.8 KB)
GCharb
osong
We're talking about textures here, and those are assigned inside the shader nodes, not in a network, and the old Principled shader works just fine in XPU here!
you are wrong. XPU does NOT understand vex shading definitions - more on that here https://www.sidefx.com/faq/karma/ [www.sidefx.com]
a simple test can be performed as such: apply VEX triplanar. It will run on Karma CPU but will fail on XPU
it must be done in mtlx nodes in this fashion
the way you are doing this is wrong, and will not work in XPU
Edited by osong - Oct. 26, 2023 07:24:23
Anyone who complains about Houdini UI/UX should spend 5 minutes in 3dsMax and Unreal
One thing more users take for granted, as they should, is that the UI is technically quite sound. It's all based on Qt and from a developers point of view it's a very nice and easy way of creating UIs. A lot of the UIs are auto generated based on the parms and a few hints on basic layout. That sort of gives you consistency by default. The foundation is sound, that's important. And sure, what's actually in the users face can use a bit of glitter.
Compared to 3dsMax for example, where it's a mix of Qt, WPF, dotnet and what not is just a mess and it shows, it can take take 10..20 seconds to open the render dialog!
In Unreal on the other hand is technically quite good as well, but consistency wise it's all quite organically grown and all over the place.
So for me Houdini's UI 'problems' are mostly UX based and I can imagine it's a bit of a hurdle if you're starting out.
More code, less clicks.
osong
I just showed you a pic where I made a very simple setup with the old principled shader, and it rendered in XPU, so I am not sure what the problem is here!
GCharb
osong
i think you are joking right now. like i said, apply triplanar, ramp, anything - it will fail. surely you cant be serious
osong
There is a QT upgrade for 2024, it would make sense to give now input to SESI.
https://vfxplatform.com/ [vfxplatform.com]
My brother made a RFE with some text and a mockup image how he wants it and 3-4 days later it was in a daily build. When it is a small task they could add it quickly.
Regarding Qt. Let's take Maya as an example, where every element of the interface is indeed translated to Qt.
1. In Houdini, it is not the same, and the problem is not that we can't do whatever we want with UI, but that errors related to Qt periodically appear in the console.
2. Why is there still no possibility to take the QWidget of the viewport? It is so convenient, considering that interactive tools using the Qt event system work slightly faster than buggy Python States.
3. Or here is an example with Python Panels that allow embedding the Qt interface. For example, if you start navigation in the viewport using Alt+RMB and release the mouse over the python panel, the navigation gets distorted. This does not happen if you release the mouse over the standard Houdini panel. It may seem like a minor thing, but it actually isn’t.
That's just the first thing that came to mind.
osong
What you are saying is that XPU is still in beta and not everything works, is that it, I am shocked! 😉
GCharb
osong
i explained it above - you are using wrong material definition, and your example is incorrect. i am not sure what exactly you don't get
osong
GCharb
osong
People talking with authority yet are ignorant on the most basic of Houdini features...
Not to do the name calling, but osong knows what they is talking about very clearly . If you disagree with them perhaps you need to re-read what they said.
Edited by kodra - Oct. 26, 2023 11:50:34
