Question about the remaining points after using Dissolve
   849   1   0
Hi everyone, I am trying out a workflow that turns a triangular surface into a quad one. When I use the dissolve node to remove an edge, it's logical that if I turn on “Remove Inline Points”, it will remove the extra points after the edge dissolved. But in practice it seems to just delete points where the point number are discontinuous with its neighboring points. As shown in the figure. I want to know if my understanding is right there ?
Oh, isn't the difference cause by the Collinearity Tolerance setting? I think it just checks the angle and deletes any points when the angle is too wide.
