Procedural PolySplit
   1767   5   0
Hi
I am trying to use hscript to drive a procedural Polysplit SOP.
In the Test_02.bgeo file I have a geometry (Test_GEO.bgeo) and a set of points (Test_POINTS.bgeo)that are scattered on the geometry border. A few of these points are not on the geometry though, and should be ignored.
I would like to insert an edge loop in the geometry starting from each of the points, using a PolySplit SOP.
I am using a For Each block. Inside it there is a Point Wrangle that I use to create a string detail attribute called @cutPoint marking the edge and position where I want the edge loop to appear in each iteration. I then feed this string to the polySplit with a
`details(-1,"cutPoint")` expression.
Unfortunately I am doing something wrong because I can not get it to work for more then a single point.
Any help on what the mistake is?
Is there an easier way to do this?
Edited by PaoloGiandoso - Nov. 8, 2023 11:22:39
Test_POINTS.bgeo (8.1 KB)
Test_02.hipnc (108.8 KB)
Test_GEO.bgeo (142.7 KB)
I think you want feedback instead merge for the loop's gather method. PolySplit was failing because it was asked to split at a non-existent location (edge #3 on a triangle). I've updated the code to determine the correct edge. It is also best not to assume a specific interpretation of the individual values in uv so the code now computes the position along the edge.
Attached is an updated example.
Test_02-2.hipnc (108.7 KB)
derrick
Amazing THANKS!
Question
with backticks instead of
why was that a mistake? Is not the attribute an expression?
I saw that toward the end you used the function vertexprimindex(0, hedge_srcvertex(0, hEdgeToCut))
Is the primitive Vertex Index the half-edge number requested by the polySplit SOP?
PaoloGiandoso
Question
I don't see any mistake there. You should be able to use backticks around the expression. I generally prefer creating a channel and writing an expression without the backticks because I find the change in colour makes it easier for me to easy notice what fields have expressions.
PaoloGiandoso
The format expected by PolySplit doesn't use half-edge numbers. Imagine enumerating the edges of a polygon. It expects that number for your edge in the polygon. This is really the same number as if you enumerated the vertices in the polygon.
derrick
When you say channel, do you mean a Keyframe? Is it the same thing?
Does creating a keyframe tells houdini to evaluate the text as an expression instead of a string?
PaoloGiandoso
Yes, that is what I mean. Once you set a keyframe, you can click on the parameter's label to switch between viewing the expression and what it evaluates to. I find this more useful than using backticks because the colour makes it easier to notice there is an expression and I can click on the label to see what value the expression produced.
