Error during Houdini Launcher 20.0.506 Windows install
   5367   8   3
I've been trying to install Houdini 20.0.506 launcher for the past two nights and I simply can not get past this error when running the "install-houdini-launcher.exe". I am on Windows 11 Version 10.0.22631 Build 22631. I have tried setting permissions on the folders, I've removed previous Houdini/launcher versions, etc.
Anyone else have this issue or can point me to what I can do to fix it please?
If you contact support@sidefx.com they can help you out with install issues. Take care!
Chris McSpurren
I used to get this because I was ticking all the addon boxes try uncheck and do standard install as it comes everything else can get added later make sure you have your licence set.
Turn off your antivirus before updating or installing Houdini Launcher.
LeoBounce
Had the same issue and this fixed it, thank you!
Pasting the whole error message since it might help others find this thread.
output folder: c:\program files\side effects software\launcher extract: uninstall houdini launcher.exe extracting files... failed to rename c:\program files\side effects software\launcher\.new to c:\program files\side effects software\launcher\20.0.547
Hey, yes it was the antivirus that blocked it for some reason. Thank you!
Same problem and same solution here: antivirus
now it works!
LeoBounce
Thank you! This issue has vexed me for years!
asorgejr
yea me too...
https://vimeo.com/jon3de [vimeo.com]
