Hi!
I'm generating my own HDA with python and everything works fine, except I can't see it in context menu. Easy to fix by removing HDA_TABLE_AND_NAME and set VOP checkbox in my case.
But how to do this with python automatically during HDA creation?
It looks like there is a tool inside HDA definition, which I suppose to be able to access and modify, but can't find a way.
How to modify HDA context visibility with python?
1553 7 2- miklem
- 43 posts
- Jonathan de Blok
- 274 posts
- miklem
- 43 posts
- Jonathan de Blok
- 274 posts
- miklem
- 43 posts
I checked API and found nothing that might help. Actually it looks like a bug or someone forgot to add API connection for this thing. I could add my HDA to the shelf and spawn it from here, for sure, but this is not an option, since I have a lot of HDAs.
Need a old_school power here
Edited by miklem - Dec. 13, 2023 11:03:04
- graham
- 1922 posts
This post might be helpful as things don't seem to have changed and any creation of HDAs via Python does not generate the default tool by default: https://www.sidefx.com/forum/topic/85634/ [www.sidefx.com]
To basically change things after the fact you're pretty much forced to take the contents of the Tools.shelf section, parse the XML into a structure you can manipulate, add/modify whatever settings you want, then set the resulting data back to the definition.
- miklem
- 43 posts
- miklem
- 43 posts
Okay, I made it work!
First here is the documentation
https://www.sidefx.com/docs/houdini20.0/shelf/config_file [www.sidefx.com]
Graham, I then took your code, and modified this part, by adding <contextNetType>VOP</contextNetType>.
Also for someone looking for the topic, there is relevant discussion
https://www.sidefx.com/forum/topic/40864/?page=1#post-183147 [www.sidefx.com]
Thank you for help.
<toolMenuContext name="network">
<contextOpType>table/operator</contextOpType>
</toolMenuContext>
Thank you for help.
Edited by miklem - Dec. 14, 2023 05:45:10
