Auto-save files in a cache node
1706 5 1- element33
- 74 posts
- Siavash Tehrani
- 711 posts
The original File Cache node can do this, very useful if you want to spit out a bunch of files from a for loop. If you have the Asset Definition Toolbar set to be visible in your parameter pane, you can just switch to the older version. The preference can be changed here:
File > Asset Manager > Configuration > Asset Definition Toolbar:
- element33
- 74 posts
Thanks. I switched to the old filecache (without the ::2.0 suffix), but what are the settings that would do it? Under Advanced Tab->Load->Missing Frame, the only options are "No Geometry" or "Report Error", there's no "Save" option. I tried checking/unchecking "Load from Disk", I switched the File Mode to Automatic/Read/Write. But I always have to push a button to actually save a missing frame: either the "Save to Disk" button or the "Reload Geometry" button. Can filecache save geo automatically, if a frame is missing?
- Siavash Tehrani
- 711 posts
- element33
- 74 posts
- vinyvince
- 255 posts
yes, why was this removed from the new filecache and not even present even the labextended cache?
It was indeed of the most usefull feature.
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
