Every time I hit update on the Houdini Launcher on Apple Silicon it quits unexpectedly.
Does anyone else have this issue?
It has full disk access and no restrictions as far as I can tell on my macOS side.
Houdini Launcher quit unexpectedly - every time I update it
1474 8 0- chf
- 168 posts
- johnmather
- 514 posts
- chf
- 168 posts
not sure if there is any sensitive information in there...
Translated Report (Full Report Below)
Incident Identifier: 461C8100-D534-4EA7-9D8B-4E0604311CAB
CrashReporter Key: 1651AA2A-B116-B973-7BFA-DB74AFCD3A5B
Hardware Model: Mac14,3
Process: houdini_launcher
Path: /Applications/Houdini Launcher.app/Contents/MacOS/houdini_launcher
Identifier: com.sidefx.HoudiniLauncher
Version: 20.0.580 (20.0.580)
Code Type: ARM-64 (Native)
Role: Unspecified
Parent Process: launchd
Coalition: com.sidefx.HoudiniLauncher
Responsible Process: houdini_launcher
Date/Time: 2024-01-08 21:14:59.1631 +0100
Launch Time: 2024-01-08 21:14:59.1601 +0100
OS Version: macOS 14.2.1 (23C71)
Release Type: User
Report Version: 104
Exception Type: EXC_CRASH (SIGKILL (Code Signature Invalid))
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: CODESIGNING 1 Taskgated Invalid Signature
Triggered by Thread: 0
Thread 0 Crashed:
0 0x104828b70 _dyld_start + 0
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000000 x1: 0x0000000000000000 x2: 0x0000000000000000 x3: 0x0000000000000000
x4: 0x0000000000000000 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x0000000000000000
x8: 0x0000000000000000 x9: 0x0000000000000000 x10: 0x0000000000000000 x11: 0x0000000000000000
x12: 0x0000000000000000 x13: 0x0000000000000000 x14: 0x0000000000000000 x15: 0x0000000000000000
x16: 0x0000000000000000 x17: 0x0000000000000000 x18: 0x0000000000000000 x19: 0x0000000000000000
x20: 0x0000000000000000 x21: 0x0000000000000000 x22: 0x0000000000000000 x23: 0x0000000000000000
x24: 0x0000000000000000 x25: 0x0000000000000000 x26: 0x0000000000000000 x27: 0x0000000000000000
x28: 0x0000000000000000 fp: 0x0000000000000000 lr: 0x0000000000000000
sp: 0x000000016bab3b48 pc: 0x0000000104828b70 cpsr: 0x00001000
far: 0x0000000000000000 esr: 0x00000000 Address size fault
Binary Images:
0x104824000 - 0x1048bbfff (*) <324e4ad9-e01f-3183-b09f-3e20b326643a> ???
0x10434c000 - 0x10444bfff (*) <263a1071-8f9b-30e0-a660-566d82ea3523> ???
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
Error Formulating Crash Report:
dyld_process_snapshot_get_shared_cache failed
EOF
Full Report
{"app_name":"houdini_launcher","timestamp":"2024-01-08 21:14:59.00 +0100","app_version":"20.0.580","slice_uuid":"263a1071-8f9b-30e0-a660-566d82ea3523","build_version":"20.0.580","platform":0,"bundleID":"com.sidefx.HoudiniLauncher","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 14.2.1 (23C71)","roots_installed":0,"name":"houdini_launcher","incident_id":"461C8100-D534-4EA7-9D8B-4E0604311CAB"}
"uptime" : 1500,
"procRole" : "Unspecified",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "Mac14,3",
"coalitionID" : 1566,
"osVersion" : {
"train" : "macOS 14.2.1",
"build" : "23C71",
"releaseType" : "User"
"captureTime" : "2024-01-08 21:14:59.1631 +0100",
"codeSigningMonitor" : 1,
"incident" : "461C8100-D534-4EA7-9D8B-4E0604311CAB",
"pid" : 1442,
"translated" : false,
"cpuType" : "ARM-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2024-01-08 21:14:59.1601 +0100",
"procStartAbsTime" : 37767156695,
"procExitAbsTime" : 37767197598,
"procName" : "houdini_launcher",
"procPath" : "\/Applications\/Houdini Launcher.app\/Contents\/MacOS\/houdini_launcher",
"bundleInfo" : {"CFBundleShortVersionString":"20.0.580","CFBundleVersion":"20.0.580","CFBundleIdentifier":"com.sidefx.HoudiniLauncher"},
"storeInfo" : {"deviceIdentifierForVendor":"DCF07147-9BE1-5D7A-9D96-D102DEC2F8B4","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.sidefx.HoudiniLauncher",
"crashReporterKey" : "1651AA2A-B116-B973-7BFA-DB74AFCD3A5B",
"responsiblePid" : 1413,
"responsibleProc" : "houdini_launcher",
"codeSigningID" : "",
"codeSigningTeamID" : "",
"codeSigningFlags" : 16777728,
"codeSigningValidationCategory" : 0,
"codeSigningTrustLevel" : 4294967295,
"instructionByteStream" : {"beforePC":"4AMA+UEEAPAh0C+R4AMUqi6iAZQoAIBSaAIAOfH\/\/xcAAAAAAAAAAA==","atPC":"4AMAkR\/sfJIdAIDSHgCA0goDABQfAACRQAAf1n8jA9X0T76p\/XsBqQ=="},
"sip" : "enabled",
"exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":,"type":"EXC_CRASH","signal":"SIGKILL (Code Signature Invalid)"},
"termination" : {"flags":66,"code":1,"namespace":"CODESIGNING","indicator":"Taskgated Invalid Signature"},
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":38459,"threadState":{"x":,"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6101351240},"esr":{"value":0,"description":" Address size fault"},"pc":{"value":4370631536,"matchesCrashFrame":1},"far":{"value":0}},"frames":}],
"usedImages" : [
"source" : "P",
"arch" : "arm64e",
"base" : 4370612224,
"size" : 622592,
"uuid" : "324e4ad9-e01f-3183-b09f-3e20b326643a",
"name" : ""
"source" : "P",
"arch" : "arm64",
"base" : 4365533184,
"size" : 1048576,
"uuid" : "263a1071-8f9b-30e0-a660-566d82ea3523",
"name" : ""
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"vmSummary" : "ReadOnly portion of Libraries: Total=2656K resident=0K(0%) swapped_out_or_unallocated=2656K(100%)\nWritable regions: Total=8176K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=8176K(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nSTACK GUARD 56.0M 1 \nStack 8176K 1 \n__DATA 48K 2 \n__DATA_CONST 64K 2 \n__DATA_DIRTY 16K 1 \n__LINKEDIT 1024K 2 \n__TEXT 1632K 2 \n=========== ======= ======= \nTOTAL 66.7M 11 \n",
"legacyInfo" : {
"threadTriggered" : {
"logWritingSignature" : "300d46694090c783b8849130ee507bf349a54a44",
"trialInfo" : {
"rollouts" : [
"rolloutId" : "6410af69ed1e1e7ab93ed169",
"factorPackIds" : {
"deploymentId" : 240000010
"rolloutId" : "63508950b3714d3622fc77f7",
"factorPackIds" : {
"SIRI_MEMORY_SYNC_CONFIG" : "63508beab3714d3622fc7808"
"deploymentId" : 240000004
"experiments" : [
"reportNotes" : [
"dyld_process_snapshot_get_shared_cache failed"
Model: Mac14,3, BootROM 10151.61.4, proc 8:4:4 processors, 16 GB, SMC
Graphics: Apple M2, Apple M2, Built-In
Display: DELL U2515H, 2560 x 1440 (QHD/WQHD - Wide Quad High Definition), Main, MirrorOff, Online
Display: DELL U2515H, 2560 x 1440 (QHD/WQHD - Wide Quad High Definition), MirrorOff, Online
Display: G247HYL, 1920 x 1080 (1080p FHD - Full High Definition), MirrorOff, Online
Memory Module: LPDDR5, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4388), wl0: Nov 3 2023 04:53:01 version 23.10.765.17.41.51.127 FWID 01-********
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
USB Device: USB31Bus
USB Device: USB3.0 Hub
USB Device: VLI Product String
USB Device: USB3.0-CRW
USB Device: USB2.0 Hub
USB Device: USB Billboard Device
USB Device: Keyboard Hub
USB Device: USB Receiver
USB Device: Apple Keyboard
USB Device: USB3 to HDMI
Thunderbolt Bus: Mac mini, Apple Inc.
Role: Unspecified
Release Type: User
Report Version: 104
Thread 0 Crashed:
Binary Images:
EOF
Full Report
"uptime" : 1500,
"version" : 2,
"userID" : 501,
"osVersion" : {
"build" : "23C71",
"pid" : 1442,
"bug_type" : "309",
"parentPid" : 1,
"sip" : "enabled",
"usedImages" : [
"source" : "P",
"arch" : "arm64e",
"size" : 622592,
"name" : ""
"source" : "P",
"arch" : "arm64",
"size" : 1048576,
"name" : ""
"size" : 0,
"source" : "A",
"base" : 0,
"legacyInfo" : {
"trialInfo" : {
"rollouts" : [
"factorPackIds" : {
"factorPackIds" : {
"experiments" : [
"reportNotes" : [
AirPort:
Edited by chf - Jan. 8, 2024 16:46:14
- chf
- 168 posts
- johnmather
- 514 posts
- chf
- 168 posts
johnmather
Have you tried downloading a newer version of the launcher from the website? The error that you're encountering seems to be related to code-signing. It's possible that a bad build was uploaded.
just did download directly from the website
updated to Houdini Launcher Version 20.0.590 M1
same thing..
- johnmather
- 514 posts
- chf
- 168 posts
johnmather
To confirm, the "same thing" is that you get a crash when you press the update button in the launcher?
yes, exactly.
It updates and then crashes.
just updated to
Houdini Launcher Version 20.0.591 M1
Compiled with AppleClang 14.0.0.14000029
crashed again
afterwards I can launch it fine and it seems to have done the update
EDIT:
this may be related?
I just installed the new production build of Houdini 20 via the launcher
it showed me this:
Warning: Expecting a LaunchAgents path since the command was ran as user. Got LaunchDaemons instead.
`launchctl bootout` is a recommended alternative.
Unload failed: 5: Input/output error
Try running `launchctl bootout` as root for richer errors.
Edited by chf - Jan. 19, 2024 13:48:39
- chf
- 168 posts
