I have built a few samples from samples/SOP/ using the hcustom command.
The build target .so ends up in my $HOME/houdini20.0/dso/ directory.
After launching Houdini, I open Texport and run dsoinfo command. I see the SOP plugins listed as loaded.
So far so good!
Now, if I do the same with plugins from samples/DM/ then I also end up with a .so file in the right directory.
But dsoinfo will not show it as loaded.
Do DM samples require a different approach to building or running compared to the SOP examples?
Thanks.
Platform: Linux RHEL9
Houdini: 20.0.591
Building and running a plugin from samples/DM/
1560 1 1- bram_stolk
- 7 posts
- bram_stolk
- 7 posts
