Hi all,
I'm facing an issue where the hbatch executable cannot be found while trying to execute jobs via a Tractor blade. The environment is set with the PATH variable, but attempts to run hbatch with specific commands for rendering operations fail, reporting that the executable is not located. Is there a way to make sure hbatch is correctly recognised, so Tractor won't bug out?
My render blade is on Windows 10. My project path is on a NAS device, with $JOB set to Y:\templates\template_tracor. Also, is the fact that windows uses backslash instead of forward slashes in the path problematic for hbatch?
Steve
"Troubleshooting hbatch Not Found with Tractor"
445 0 1- Stephen Davidson
- 15 posts
