Scale an object and keep position | VOPs xform
   1134   7   1
Hello, is it possible to use the xform vop to scale an object uniformly, while keeping its position (pivot)?
I've tried doing it in vex and with a transform node, but neither worked.
The transform node would have worked, except you can't drive the uniform scale parameter with an attribute.
scale by the center and not so that it moves to the 0 origin while scaling.png (230.2 KB)
This is what it would look like with a transform node (except you cant use a custom attribute for uniform scale).
Screenshot 2024-04-04 220112.png (491.3 KB)
transform SOP, why you cant use a custom attribute for uniform scale?
I tried doing that and it just turns green and stays at 0. My scale attribute is updating each frame so I guess that's why it doesn't work?
scale attrib update each frame. But I am still correct here
So it seems to be something with my attribute being a point attribute. I tried filling it in the transform like your detail attribute example, but it doesn't like the syntax.
Edited by CreativeWaves - April 4, 2024 11:18:56
Screenshot 2024-04-04 231732.png (216.6 KB)
try `point(0,0,'final',0)`
because `point` need point number, `detail` do not required
Oh your right, that fixed it. Appreciate that!
Edited by CreativeWaves - April 4, 2024 11:28:41
