Can use Eigen C++ library in Vex or OpenCL?
2596 6 1-
- ljzmathematics
- 5 posts
- juejuezi
- 34 posts
- animatrix_
- 5097 posts
You can use it inside Houdini using C++ Wrangle:
This guy integrated the Eigen library also:
https://github.com/lecopivo/cpp-wrangle [github.com]
So you can try that version to access the Eigen library directly. This is the closest you can get albeit not inside VEX or OpenCL.
- ljzmathematics
- 5 posts
juejueziThank you very much for your suggestion. I actually have a small problem with HDK. Every time I recompile the plug-in, I have to restart Houdini to recognize it. This is a bit annoying. Is there a way to make Houdini detect custom node updates in real time?
use eigen in vex:
HDK: Custom Vex Function [www.sidefx.com]
But it's still inconvenient
- ljzmathematics
- 5 posts
animatrix_Many thanks for your advice, looks like a very good and interesting solution!
- animatrix_
- 5097 posts
ljzmathematicsjuejueziThank you very much for your suggestion. I actually have a small problem with HDK. Every time I recompile the plug-in, I have to restart Houdini to recognize it. This is a bit annoying. Is there a way to make Houdini detect custom node updates in real time?
use eigen in vex:
The C++ Wrangle SOP won't have this problem. It will only compile if the code is changed or it's run on a new system where it wasn't compiled before or a new version of Houdini that uses a new compiler. The same binaries will be used indefinitely.
SESI did a great job with C++ integration albeit it's not really popularized.
- juejuezi
- 34 posts
ljzmathematicsAs far as I know, there is no way to automatically update. But you can try the C++ Wrangle SOPjuejueziThank you very much for your suggestion. I actually have a small problem with HDK. Every time I recompile the plug-in, I have to restart Houdini to recognize it. This is a bit annoying. Is there a way to make Houdini detect custom node updates in real time?
use eigen in vex:
