Hi, just wondering if anyone else has experienced something like this/ has a solution:
I have a basic architectural environment in a scene with some scattering and props etc. All is fine and good, it renders snappy in the viewport until I hop into a camera....any tweaks I make will take an eternity to update and I have no idea why. It's not switching render prims as far as I can tell and I have it set to half res in the viewport (this is happening with Redshift and karma)
thanks in advance!
Render Camera Slow to update but native cam is fast?
2225 4 1- Galleryworm
- 21 posts
- Antti1999
- 41 posts
- 8045 posts
This is most likely due to cooking a complex graph after the camera. Is your camera node being edited at the top of a long change of LOP nodes? This would trigger all of these nodes to recook when modifying the camera. For best performance, use a merge at the bottom of the chain to combine your scene, your lights, and your cameras. This way editing lights and cameras stays performant even with more complex scenes.
- Galleryworm
- 21 posts
- luisguggenberger
- 13 posts
I was able to fix it for me. It was the Scene Import bringing in the Materials. I had a stonewall with tons of named individual pieces. For some reason the material got recooked on all stones whenever I moved the camera. I deleted the name attribute, so it came in as one mesh and the lag was gone.
Edited by luisguggenberger - April 11, 2024 05:57:29
