I'm not sure if I understand the licensing correctly, but it seems that Houdini Indie license allows installing Houdini itself on two computers, and then I also see "Karma/Mantra tokens", which are 2 of each.
My question is, what kinds of setup does this allow in terms of using more than one computer to render? Can I actually use this to render on the two machines, since I'll be still "one user"?
Rendering on a second machine with Houdini Indie
1001 2 0- darth
- 7 posts
- jandress
- 44 posts
You can find Indie faqs here:
https://www.sidefx.com/faq/indie-new/ [www.sidefx.com]
You can't use Houdini(Interface) on both machines at once, but you can set up a render farm using Hqueue with up to 3 nodes with Houdini engine and Karma/Mantra licenses.
- atitimar
- 5 posts
