hou.ui.readInput() Only output zero at the first tuple
   Views 1210   Replies 4   Subscribers 0
No matter which button I press, It always output zero at the first tuple...
input = hou.ui.readInput("Test Button Output", default_choice=0, close_choice=-1)
print(input)
if input[0] == -1:
    print("exit")
if input[0] == 0:
    print("enter")
# It always output 0 on input[0] but it should be -1 if I press exit button or esc
Edited by artchapter - May 20, 2022 06:27:28
Sample_readinput.hip (86.5 KB)
hello,
i'm experiencing the same issue actually on Houdini 19
As it follows from the documentation: The integer is the index of the pressed button.
This is necessary for those cases when you have more than one button by default the button argument is 'OK', if you make a tuple containing more than one button it will return the corresponding index.
yeah i had to replace our solution by a pyside dialog that support close event
It actually works using a Cancel Button and close_choice=1
result,comment = hou.ui.readInput("Add your entry:", title="String input", initial_contents="", buttons=("OK", "Cancel"),close_choice=1)
if result == 1 : return
else : return comment
Edited by sebd3dvfx - May 6, 2024 09:42:30
