Hi!
I downloaded a third-party HDA when I try to install it, it gives me this error and the HDA itself does not work correctly! Who can tell you how to solve this problem??? I've never worked with python!
Python Callback Error
File "<stdin>", line 1
{ 'event_type': hou.hdaEventType.LibraryInstalled, 'library_path' : 'E:/Material for work/SipiLib HDA's/sipiLib-main/otls/sipi-vectornoise-1.0.0.hda' }
SyntaxError: unterminated string literal (detected at line 1)
1070 2 1- drouviii
- 5 posts
- alexwheezy
- 318 posts
cvsline
In python, strings are usually enclosed in single or double quotes and their number must be balanced. The script finds another single quote in your HDA's path that is in no way unbalanced. If possible, it is better not to use special characters in the path at all, including whatespaces, and replace them either with underscores or dashes.
- drouviii
- 5 posts
alexwheezycvsline
Thank you very much! I really removed both the names 'hyphen' and 'space' in the path and everything began to work as it should and not give out any error! It helped a lot! I am grateful!
Edited by drouviii - May 3, 2024 04:13:06
