Restrict specific Rotation and Position with RBD
958 5 1- adro
- 6 posts
Hi! I'm working on a personal project where I need to make a medieval type Stone Wall.
I used the uv layout method to place the stones, now I'd like to do a simple rbd sim to de-intersect using the found_overlap trick.
I need the sim to not move on Z Position and Y Rotation. Using @P=0; on a Geometry Wrangle helps but it transforms the stones to the center (It needs to respect the pre-sim Z Position).
Edited by adro - May 1, 2024 03:57:39
- Honza Topinka
- 12 posts
- adro
- 6 posts
Thanks for the reply Honza,
I haven't been able to reproduce your solution, I'm new to rbd and dops sorry
This is the code I tried for the geometry wrangle (connected to postsolve)
As I mention on the start, this is part of a medieval wall. My objective with the rbd part is to give more variety to the uv-layout result and get something like this texture [quixel.com].
This is my progress so far, but a lot of stones still intersect. The stones are all packed primitives.
If you can provide an example it would be very helpful
vector rest = point(0, "rest", 0); @P[2] = rest[2]; # no idea on how to restrict the y rotation
Edited by adro - May 6, 2024 07:14:47
- Benyee
- 59 posts
- Ruteger1
- 9 posts
- adro
- 6 posts
