I import a detail attribute using sop import lop.
I notice that there is a empty indices attribute being created side by side.
What meaning about it?
Import detail attribute create indices?
711 3 0-
- jerry7
- 658 posts
- 9043 posts
should not be detail specific are you not getting it for point, prim, vertex attribute?
every custom attribute should give you separate :indices array, which is populated by indices if you import attribute as indexed primvar otherwise is empty, but it's important it is there in case you are layering nonindexed primvar over indexed one, as then it needs to zero out the indices array
Edited by tamte - May 8, 2024 03:45:56
- jerry7
- 658 posts
- mtucker
- 4527 posts
