I am super new with Houdini. I have a simple muscle setup and I cooked around 400 frames. However only the last 50 frames or so are cooked and the ones from 1 to 290 are all gone?? I can only see the cooked blue section.
Is there a settings or something I can do? So I can see the entire cooked timeline and not just the last frames (and yes I waited to cook everything).
Houdini won't cook all the frames I selected
442 1 0- Alexandra_Chiosa
- 23 posts
- Enivob
- 2617 posts
That blue bar represents the window into your physical memory cache. It defaults to 5Gb. You can expand it to use more of your physical ram, but a better approach it so write your simulation out to a dedicated file sequence using the FileCache node. Check the help card. Once you have a file cache, you can scrub the simulation much quicker, and not have to "re-cook" every time.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
