may I ask how to open the “houdini console” window in the Mac OS version of Houdini?
thanks!
how to open "Houdini Console" in Mac version of Ho
16212 5 4- oat
- 479 posts
- graham
- 1921 posts
There is no specific console window on OS X or linux. If you want console output you'll need to start Houdini from a terminal. To do this on OS X you can use the Houdini Shell.terminal link in the application folder and type in ‘houdini’. As with linux, you can also navigate to the installation directory and source houdini_setup and then run ‘houdini’.
- knackbrot
- 40 posts
- Neonzone
- 33 posts
found this old post - because was looking for the same - here is my updated nodelist, inclusive mops, in JSON:
{ "polysplit": "polysplit", "wire": "wire", "heightfield_scatter::2.0": "heightfield_scatter::2.0", "agentunpack": "agentunpack", "heightfield_remap": "heightfield_remap", "gamedev::sop_delight": "gamedev::sop_delight", "heightfield_project": "heightfield_project", "heightfield_erode::2.0": "heightfield_erode::2.0", "oceansource": "oceansource", "hole": "hole", "rbdpaint": "rbdpaint", "volumeanalysis": "volumeanalysis", "Sop/rbdmaterialfracture::rbdconcretefracture": "Sop/rbdmaterialfracture::rbdconcretefracture", "vex": "vex", "heightfield_copylayer": "heightfield_copylayer", "ripple::2.0": "ripple::2.0", "gamedev::rop_volume_texture": "gamedev::rop_volume_texture", "volumeblur": "volumeblur", "slidemodifierpaint": "slidemodifierpaint", "resample": "resample", "matchtopology": "matchtopology", "agentedit": "agentedit", "packgroom": "packgroom", "guidegroup": "guidegroup", "block_begin": "block_begin", "crowdsource": "crowdsource", "gamedev::sop_physics_painter": "gamedev::sop_physics_painter", "blast": "blast", "fractal": "fractal", "heightfield_patch": "heightfield_patch", "solver": "solver", "vertex": "vertex", "magnet": "magnet", "vdbreshapesdf": "vdbreshapesdf", "waveform": "waveform", "volumefeather": "volumefeather", "repack": "repack", "uvunwrap": "uvunwrap", "cap": "cap", "force": "force", "timeblend": "timeblend", "agentprep": "agentprep", "gamedev::sop_make_loop": "gamedev::sop_make_loop", "MOPS::Relax_Copies::1.0": "MOPS::Relax_Copies::1.0", "xformaxis": "xformaxis", "polyloft": "polyloft", "volumevop": "volumevop", "volumefft": "volumefft", "cloudnoise": "cloudnoise", "deformmeta": "deformmeta", "MOPS::Parallel_Transport::1.0": "MOPS::Parallel_Transport::1.0", "edgecusp": "edgecusp", "unpaste": "unpaste", "fillet": "fillet", "vdbfracture": "vdbfracture", "uvlayout": "uvlayout", "vdbtopologytosdf": "vdbtopologytosdf", "MOPS::Flocking::1.0": "MOPS::Flocking::1.0", "gamedev::sop_color_blend": "gamedev::sop_color_blend", "bakeode": "bakeode", "gamedev::sop_mesh_tiler": "gamedev::sop_mesh_tiler", "sopnet": "sopnet", "groomblend": "groomblend", "primitivesplit": "primitivesplit", "captureproximity": "captureproximity", "MOPS::Remap_Falloff::1.0": "MOPS::Remap_Falloff::1.0", "join": "join", "vdbpointsgroup": "vdbpointsgroup", "attribrandomize": "attribrandomize", "tristrip": "tristrip", "voronoifracturepoints": "voronoifracturepoints", "vdbclip": "vdbclip", "vopnet": "vopnet", "gltf": "gltf", "box": "box", "convert": "convert", "oceanevaluate::2.0": "oceanevaluate::2.0", "testgeometry_shaderball": "testgeometry_shaderball", "remesh": "remesh", "grouppromote": "grouppromote", "uvlayout::2.0": "uvlayout::2.0", "boolean::2.0": "boolean::2.0", "scatter": "scatter", "uvflatten::2.0": "uvflatten::2.0", "sblend::2.0": "sblend::2.0", "visibility": "visibility", "attribnoise": "attribnoise", "crowdsource::2.0": "crowdsource::2.0", "agentvellumunpack": "agentvellumunpack", "pack": "pack", "flipsource": "flipsource", "filemerge": "filemerge", "vellumsolver": "vellumsolver", "divide": "divide", "guideprocess": "guideprocess", "layer": "layer", "agentprep::3.0": "agentprep::3.0", "unix": "unix", "MOPS::MOPs_Spread_Falloff::1.1": "MOPS::MOPs_Spread_Falloff::1.1", "alembicprimitive": "alembicprimitive", "attribcopy": "attribcopy", "heightfield_quickshade": "heightfield_quickshade", "cloud": "cloud", "heightfield_terrace": "heightfield_terrace", "graphcolor": "graphcolor", "gamedev::sop_soften_normals": "gamedev::sop_soften_normals", "volumebreak": "volumebreak", "gamedev::rbd_solver": "gamedev::rbd_solver", "dopio": "dopio", "objnet": "objnet", "duplicate": "duplicate", "bonecapturebiharmonic": "bonecapturebiharmonic", "finalizewaves": "finalizewaves", "gamedev::sop_group_by_color": "gamedev::sop_group_by_color", "volumerasterizehair": "volumerasterizehair", "connectadjacentpieces": "connectadjacentpieces", "heightfield_isolatelayer": "heightfield_isolatelayer", "relax": "relax", "guidetangentspace": "guidetangentspace", "starburst": "starburst", "falloff": "falloff", "uvflatten": "uvflatten", "planarpleat": "planarpleat", "testgeometry_crag": "testgeometry_crag", "vectordeform": "vectordeform", "gamedev::sop_simple_baker": "gamedev::sop_simple_baker", "agent": "agent", "gamedev::sop_box_clip": "gamedev::sop_box_clip", "posescope": "posescope", "findshortestpath": "findshortestpath", "unpack": "unpack", "gamedev::sop_group_attribute_borders": "gamedev::sop_group_attribute_borders", "smooth::2.0": "smooth::2.0", "hairclump": "hairclump", "gamedev::sop_static_fracture_export": "gamedev::sop_static_fracture_export", "vdbfrompolygons": "vdbfrompolygons", "gamedev::sop_visualize_uvs": "gamedev::sop_visualize_uvs", "extractcentroid": "extractcentroid", "stroke": "stroke", "vellumconstraints": "vellumconstraints", "Object/musclerig::musclerigstrokebuilder": "Object/musclerig::musclerigstrokebuilder", "gamedev::sop_instant_meshes": "gamedev::sop_instant_meshes", "capturemeta": "capturemeta", "ropnet": "ropnet", "dissolve": "dissolve", "attribpromote": "attribpromote", "control": "control", "metagroups": "metagroups", "groupcopy": "groupcopy", "attribute": "attribute", "bonelink": "bonelink", "guidegroom": "guidegroom", "deformmuscle": "deformmuscle", "heightfield_maskbyfeature": "heightfield_maskbyfeature", "sphere": "sphere", "gamedev::sop_sweep_geometry": "gamedev::sop_sweep_geometry", "vdbtospheres": "vdbtospheres", "bend": "bend", "vdbresample": "vdbresample", "volumesurface": "volumesurface", "particlefluidtank": "particlefluidtank", "posespacedeformcombine": "posespacedeformcombine", "volumevisualization": "volumevisualization", "gamedev::sop_rbd_fracture": "gamedev::sop_rbd_fracture", "vellumpostprocess": "vellumpostprocess", "dopimportrecords": "dopimportrecords", "foreach": "foreach", "attribfind": "attribfind", "uvautoseam": "uvautoseam", "attribwrangle": "attribwrangle", "attribfrommap": "attribfrommap", "hairgen": "hairgen", "profile": "profile", "hairgencore": "hairgencore", "vdbvectorsplit": "vdbvectorsplit", "pointmap": "pointmap", "vellumio": "vellumio", "connectivity": "connectivity", "wiredeform": "wiredeform", "volumevelocityfromcurves": "volumevelocityfromcurves", "heightfield_erode": "heightfield_erode", "edgeflip": "edgeflip", "MOPS::Sweep_Spline::1.0": "MOPS::Sweep_Spline::1.0", "stash": "stash", "gamedev::niagara_impacts": "gamedev::niagara_impacts", "drawcurve": "drawcurve", "MOPS::Subdivider::1.0": "MOPS::Subdivider::1.0", "superquad": "superquad", "agentcollisionlayer": "agentcollisionlayer", "attribvop": "attribvop", "deform": "deform", "MOPS::Spline_Falloff::1.0": "MOPS::Spline_Falloff::1.0", "timeshift": "timeshift", "grainsource": "grainsource", "wavevelocity": "wavevelocity", "revolve": "revolve", "heightfield_drawmask": "heightfield_drawmask", "MOPS::Randomize::1.1": "MOPS::Randomize::1.1", "MOPS::Randomize::1.0": "MOPS::Randomize::1.0", "platonic": "platonic", "volumesplice": "volumesplice", "groomswitch": "groomswitch", "attribtransferbyuv": "attribtransferbyuv", "attribreorient": "attribreorient", "cloudlight": "cloudlight", "group": "group", "edgefracture": "edgefracture", "fit": "fit", "heightfield_file": "heightfield_file", "solidembed": "solidembed", "unpackpoints": "unpackpoints", "gamedev::sop_measure_curvarture": "gamedev::sop_measure_curvarture", "carve": "carve", "gamedev::sop_merge_small_islands": "gamedev::sop_merge_small_islands", "heightfield_layer": "heightfield_layer", "block_end": "block_end", "MOPS::Set_Sequence_Time::1.0": "MOPS::Set_Sequence_Time::1.0", "material": "material", "shatter": "shatter", "trail": "trail", "break": "break", "volumepatch": "volumepatch", "filament_advect_pos": "filament_advect_pos", "polypatch": "polypatch", "heightfield_resample": "heightfield_resample", "uvlayout::3.0": "uvlayout::3.0", "gamedev::sop_calculate_occlusion": "gamedev::sop_calculate_occlusion", "wirecapture": "wirecapture", "adaptiveprune": "adaptiveprune", "name": "name", "polybridge": "polybridge", "edit": "edit", "gamedev::sop_thicken": "gamedev::sop_thicken", "merge": "merge", "heightfield_layerclear": "heightfield_layerclear", "vdbsmooth": "vdbsmooth", "each": "each", "extrudevolume": "extrudevolume", "groupdelete": "groupdelete", "vdbcombine": "vdbcombine", "rbdinteriordetail": "rbdinteriordetail", "gamedev::sop_disc_generator": "gamedev::sop_disc_generator", "heightfield_blur": "heightfield_blur", "whitewatersource::2.0": "whitewatersource::2.0", "mdd": "mdd", "rop_gltf": "rop_gltf", "gamedev::sop_extract_filename": "gamedev::sop_extract_filename", "paintsdfvolume": "paintsdfvolume", "measure": "measure", "ripple": "ripple", "vdbfromparticles": "vdbfromparticles", "convertvdbpoints": "convertvdbpoints", "subnet": "subnet", "grouprange": "grouprange", "polybevel": "polybevel", "network": "network", "MOPS::indexFromAttribute::1.0": "MOPS::indexFromAttribute::1.0", "edgetransport": "edgetransport", "collisionsource": "collisionsource", "gamedev::sop_mapbox": "gamedev::sop_mapbox", "planarpatchfromcurves": "planarpatchfromcurves", "tetrahedralize": "tetrahedralize", "agentclip": "agentclip", "vdbvisualizetree": "vdbvisualizetree", "uvproject": "uvproject", "vdbmorphsdf": "vdbmorphsdf", "testgeometry_squab": "testgeometry_squab", "cookie": "cookie", "polyreduce::2.0": "polyreduce::2.0", "convexdecomposition": "convexdecomposition", "capturecorrect": "capturecorrect", "MOPS::Explode::1.0": "MOPS::Explode::1.0", "volumerasterizeattributes": "volumerasterizeattributes", "MOPS::delay::1.0": "MOPS::delay::1.0", "alembicgroup": "alembicgroup", "gamedev::sop_unreal_pivotpainter": "gamedev::sop_unreal_pivotpainter", "heightfield_xform": "heightfield_xform", "round": "round", "guideadvect": "guideadvect", "iso": "iso", "grouptransfer": "grouptransfer", "gamedev::sop_flowmap_obstacle": "gamedev::sop_flowmap_obstacle", "fluidsource": "fluidsource", "vopsoptype": "vopsoptype", "clothcapture": "clothcapture", "extrude": "extrude", "heightfield_visualize": "heightfield_visualize", "polyknit": "polyknit", "sssscatter": "sssscatter", "enumerate": "enumerate", "gamedev::sop_terrain_segment_rop": "gamedev::sop_terrain_segment_rop", "gamedev::sop_quickmaterial": "gamedev::sop_quickmaterial", "dopimport": "dopimport", "heightfield": "heightfield", "extracttransform": "extracttransform", "volumerasterize": "volumerasterize", "pointjitter": "pointjitter", "polyexpand2d": "polyexpand2d", "blendshapes::2.0": "blendshapes::2.0", "script": "script", "guideskinattriblookup": "guideskinattriblookup", "rails": "rails", "gamedev::simple_rbd": "gamedev::simple_rbd", "paint": "paint", "vdblod": "vdblod", "polyextrude::2.0": "polyextrude::2.0", "inflate": "inflate", "MOPS::Mesh_Flow::1.0": "MOPS::Mesh_Flow::1.0", "MOPS::Mesh_Flow::1.1": "MOPS::Mesh_Flow::1.1", "attribblur": "attribblur", "attribfade": "attribfade", "attribcreate::2.0": "attribcreate::2.0", "agentdefinitioncache": "agentdefinitioncache", "groomfetch": "groomfetch", "copy": "copy", "MOPS::Object_Falloff::1.0": "MOPS::Object_Falloff::1.0", "xform": "xform", "fluidcompress": "fluidcompress", "gamedev::rbd_director": "gamedev::rbd_director", "vdbadvectpoints": "vdbadvectpoints", "vertexsplit": "vertexsplit", "heightfield_maskbyshadow": "heightfield_maskbyshadow", "project": "project", "agentconfigurejoints": "agentconfigurejoints", "convertvolume": "convertvolume", "bridge": "bridge", "clip": "clip", "agentproxy": "agentproxy", "cop2net": "cop2net", "lsystem": "lsystem", "topobuild": "topobuild", "constraintnetwork": "constraintnetwork", "gamedev::sop_flowmap_visualize": "gamedev::sop_flowmap_visualize", "scatter::2.0": "scatter::2.0", "pointdeform": "pointdeform", "gamedev::sop_terrain_texture_rop": "gamedev::sop_terrain_texture_rop", "ray": "ray", "mountain": "mountain", "posespacedeform": "posespacedeform", "tetrahedralize::2.0": "tetrahedralize::2.0", "groupexpression": "groupexpression", "polyfill": "polyfill", "pointvelocity": "pointvelocity", "pointreplicate": "pointreplicate", "switch": "switch", "paintcolorvolume": "paintcolorvolume", "gamedev::sop_polydeform": "gamedev::sop_polydeform", "MOPS::Shape_Falloff::1.1": "MOPS::Shape_Falloff::1.1", "pointcloudiso": "pointcloudiso", "deltamush": "deltamush", "channel": "channel", "polypath": "polypath", "attribinterpolate": "attribinterpolate", "MOPS::Transform_Falloff::1.0": "MOPS::Transform_Falloff::1.0", "guidepartition": "guidepartition", "trace": "trace", "normal": "normal", "captureattribpack": "captureattribpack", "toonshaderattribs": "toonshaderattribs", "heightfield_slump": "heightfield_slump", "bakevex": "bakevex", "solidify::2.0": "solidify::2.0", "MOPS::Extract_Attributes::1.0": "MOPS::Extract_Attributes::1.0", "gamedev::sop_skinning_converter": "gamedev::sop_skinning_converter", "guidedeform": "guidedeform", "filecache": "filecache", "hairgrowthfield": "hairgrowthfield", "agenttransformgroup": "agenttransformgroup", "torus": "torus", "partition": "partition", "attribmirror": "attribmirror", "polycap": "polycap", "clean": "clean", "heightfield_paint": "heightfield_paint", "attribstringedit": "attribstringedit", "pointsfromvolume": "pointsfromvolume", "shop": "shop", "edgedivide": "edgedivide", "Sop/rbdmaterialfracture::rbdwoodfracture": "Sop/rbdmaterialfracture::rbdwoodfracture", "hairclump::2.0": "hairclump::2.0", "vdbactivate": "vdbactivate", "uvtransform": "uvtransform", "gamedev::sop_remove_inside_faces": "gamedev::sop_remove_inside_faces", "guidedraw": "guidedraw", "grouppaint": "grouppaint", "font": "font", "posespaceedit": "posespaceedit", "gamedev::sop_multi_file": "gamedev::sop_multi_file", "gamedev::sop_group_by_attribute": "gamedev::sop_group_by_attribute", "cache": "cache", "volumevelocity": "volumevelocity", "texture": "texture", "attribexpression": "attribexpression", "gamedev::sop_flowmap_guide": "gamedev::sop_flowmap_guide", "heightfield_layerproperty": "heightfield_layerproperty", "circle": "circle", "gamedev::niagara_interpolate": "gamedev::niagara_interpolate", "matnet": "matnet", "gamedev::sop_sketchfab_output": "gamedev::sop_sketchfab_output", "bonedeform": "bonedeform", "invoke": "invoke", "popnet": "popnet", "vdbfromparticlefluid": "vdbfromparticlefluid", "heightfield_erode_precipitation": "heightfield_erode_precipitation", "uvfuse": "uvfuse", "pointgenerate": "pointgenerate", "polyreduce": "polyreduce", "muscledeform": "muscledeform", "agentrelationship": "agentrelationship", "uvflatten::3.0": "uvflatten::3.0", "heightfield_erode_hydro": "heightfield_erode_hydro", "vdbrenormalizesdf": "vdbrenormalizesdf", "solidconform": "solidconform", "heightfield_pattern": "heightfield_pattern", "MOPS::Color_Modifier::1.0": "MOPS::Color_Modifier::1.0", "gamedev::sop_destruction_cleanup": "gamedev::sop_destruction_cleanup", "smooth": "smooth", "voronoifracture": "voronoifracture", "agentprep::2.0": "agentprep::2.0", "intersectionstitch": "intersectionstitch", "polystitch": "polystitch", "curveclay": "curveclay", "polywire": "polywire", "MOPS::Instancer::1.1": "MOPS::Instancer::1.1", "MOPS::Instancer::1.0": "MOPS::Instancer::1.0", "clothdeform": "clothdeform", "gamedev::sop_mark_seams": "gamedev::sop_mark_seams", "rbdcluster": "rbdcluster", "captureattribunpack": "captureattribunpack", "rewire": "rewire", "heightfield_crop": "heightfield_crop", "volumestamp": "volumestamp", "wireblend": "wireblend", "solidfracture::2.0": "solidfracture::2.0", "vdbanalysis": "vdbanalysis", "polydoctor": "polydoctor", "ends": "ends", "agentcliptransitiongraph": "agentcliptransitiongraph", "gamedev::sop_cylinder_generator": "gamedev::sop_cylinder_generator", "MOPS::Audio_Falloff:1.0": "MOPS::Audio_Falloff:1.0", "bakevolume": "bakevolume", "refine": "refine", "oceanspectrum": "oceanspectrum", "heightfield_flowfield": "heightfield_flowfield", "oceanevaluate": "oceanevaluate", "MOPS::Noise_Falloff::1.0": "MOPS::Noise_Falloff::1.0", "gamedev::sop_extract_borders": "gamedev::sop_extract_borders", "comb": "comb", "collisionsource::2.0": "collisionsource::2.0", "loadslices": "loadslices", "object_merge": "object_merge", "gamedev::sop_color_adjustment": "gamedev::sop_color_adjustment", "volumearrivaltime": "volumearrivaltime", "rbdpack": "rbdpack", "reverse": "reverse", "volumefromattrib": "volumefromattrib", "chopnet": "chopnet", "volumerasterizepoints": "volumerasterizepoints", "facet": "facet", "guideinit": "guideinit", "polybevel::2.0": "polybevel::2.0", "gamedev::sop_axis_align": "gamedev::sop_axis_align", "Sop/rbdmaterialfracture::rbdglassfracture": "Sop/rbdmaterialfracture::rbdglassfracture", "uvpelt::2.0": "uvpelt::2.0", "point": "point", "color": "color", "sky": "sky", "gamedev::sop_flowmap_obstacle::2.0": "gamedev::sop_flowmap_obstacle::2.0", "gamedev::sop_delete_small_parts": "gamedev::sop_delete_small_parts", "blendshapes": "blendshapes", "sweep": "sweep", "pop": "pop", "vopsop": "vopsop", "xformbyattrib": "xformbyattrib", "agentlookat::2.0": "agentlookat::2.0", "gamedev::sop_edgegroup_to_curve": "gamedev::sop_edgegroup_to_curve", "gamedev::sop_turntable": "gamedev::sop_turntable", "gamedev::sphere_generator": "gamedev::sphere_generator", "basis": "basis", "volumecompress": "volumecompress", "MOPS::Plain_Falloff::1.0": "MOPS::Plain_Falloff::1.0", "voronoisplit": "voronoisplit", "Object/riggedmuscle::musclestrokebuilder": "Object/riggedmuscle::musclestrokebuilder", "polysplit::2.0": "polysplit::2.0", "volumebound": "volumebound", "agentconstraintnetwork": "agentconstraintnetwork", "heightfield_maskbyocclusion": "heightfield_maskbyocclusion", "groupcreate": "groupcreate", "whitewatersource": "whitewatersource", "surfsect": "surfsect", "intersectionanalysis": "intersectionanalysis", "volumeresample": "volumeresample", "sprite": "sprite", "vdbadvectsdf": "vdbadvectsdf", "volumereduce": "volumereduce", "uvedit": "uvedit", "windingnumber": "windingnumber", "gamedev::sop_uv_unitize": "gamedev::sop_uv_unitize", "vdbocclusionmask": "vdbocclusionmask", "cregion": "cregion", "fur": "fur", "sculpt": "sculpt", "align": "align", "copyxform": "copyxform", "crowdsource::3.0": "crowdsource::3.0", "error": "error", "shopnet": "shopnet", "MOPS::Falloff_From_Attribute::1.0": "MOPS::Falloff_From_Attribute::1.0", "gamedev::sop_flowmap": "gamedev::sop_flowmap", "convertmeta": "convertmeta", "Sop/rbdmaterialfracture::rbdrecursivefracture": "Sop/rbdmaterialfracture::rbdrecursivefracture", "curvesect": "curvesect", "MOPS::MOPs_Spread_Falloff::1.0": "MOPS::MOPs_Spread_Falloff::1.0", "attribtransfer": "attribtransfer", "MOPS::Texture_Falloff::1.0": "MOPS::Texture_Falloff::1.0", "gamedev::inside_face_uvs": "gamedev::inside_face_uvs", "booleanfracture": "booleanfracture", "cluster": "cluster", "retime": "retime", "reguide": "reguide", "tableimport": "tableimport", "capture": "capture", "null": "null", "tetpartition": "tetpartition", "MOPS::Aim::1.0": "MOPS::Aim::1.0", "python": "python", "vellumrestblend": "vellumrestblend", "split": "split", "drawhair": "drawhair", "heightfield_scatter": "heightfield_scatter", "triangulate2d::3.0": "triangulate2d::3.0", "packededit": "packededit", "captureoverride": "captureoverride", "dopimportfield": "dopimportfield", "groupcombine": "groupcombine", "xformpieces": "xformpieces", "vellumconstraints_grain": "vellumconstraints_grain", "fuse": "fuse", "agentlayer": "agentlayer", "oceanfoam": "oceanfoam", "clusterpoints": "clusterpoints", "volumevelocityfromsurface": "volumevelocityfromsurface", "voronoifracture::2.0": "voronoifracture::2.0", "rop_geometry": "rop_geometry", "particlefluidsurface": "particlefluidsurface", "pyrosource": "pyrosource", "rbdmaterialfracture": "rbdmaterialfracture", "compile_begin": "compile_begin", "debrissource": "debrissource", "agentterrainadaptation": "agentterrainadaptation", "packeddiskedit": "packeddiskedit", "MOPS::MOPs_Move_Along_Mesh::1.0": "MOPS::MOPs_Move_Along_Mesh::1.0", "muscle": "muscle", "bonecapturelines": "bonecapturelines", "agentclipproperties": "agentclipproperties", "skin": "skin", "gamedev::sop_sine_wave": "gamedev::sop_sine_wave", "rest": "rest", "MOPS::Curl_Modifier::1.0": "MOPS::Curl_Modifier::1.0", "explodedview": "explodedview", "heightfield_erode_thermal": "heightfield_erode_thermal", "volumemerge": "volumemerge", "guidecollidevdb": "guidecollidevdb", "instance": "instance", "opencl": "opencl", "attribcreate": "attribcreate", "rop_fbx": "rop_fbx", "guidemaskcore": "guidemaskcore", "add": "add", "polycut": "polycut", "verify_bsdf": "verify_bsdf", "isooffset": "isooffset", "attribfromvolume": "attribfromvolume", "oceanwaves": "oceanwaves", "testsim_ragdoll": "testsim_ragdoll", "particlefluidsurface::2.0": "particlefluidsurface::2.0", "edgecollapse": "edgecollapse", "polyspline": "polyspline", "deformationwrangle": "deformationwrangle", "gamedev::sop_gameres": "gamedev::sop_gameres", "MOPS::Spring_Modifier::1.0": "MOPS::Spring_Modifier::1.0", "volumeopticalflow": "volumeopticalflow", "grid": "grid", "MOPS::Neighbors::1.0": "MOPS::Neighbors::1.0", "gamedev::rop_vector_field": "gamedev::rop_vector_field", "gamedev::sop_group_edge_loop": "gamedev::sop_group_edge_loop", "polysoup": "polysoup", "convertvdb": "convertvdb", "particle": "particle", "bulge": "bulge", "fevisualization": "fevisualization", "gamedev::sop_detail_mesh": "gamedev::sop_detail_mesh", "MOPS::MOPS_Convert::1.0": "MOPS::MOPS_Convert::1.0", "gamedev::niagara_rop": "gamedev::niagara_rop", "vdb": "vdb", "clay": "clay", "output": "output", "lidarimport": "lidarimport", "MOPS::Shape_Falloff::1.0": "MOPS::Shape_Falloff::1.0", "copytopoints": "copytopoints", "unpackgroom": "unpackgroom", "testsim_crowdtransition": "testsim_crowdtransition", "compile_end": "compile_end", "guidetransfer": "guidetransfer", "MOPS::Reorient::1.0": "MOPS::Reorient::1.0", "heightfield_noise": "heightfield_noise", "vdbsmoothsdf": "vdbsmoothsdf", "metaball": "metaball", "mirror": "mirror", "detangle": "detangle", "heightfield_tilesplit": "heightfield_tilesplit", "creep": "creep", "tribez": "tribez", "gamedev::sop_quickmaterial::2.0": "gamedev::sop_quickmaterial::2.0", "capturemirror": "capturemirror", "vdbactivatesdf": "vdbactivatesdf", "heightfield_output": "heightfield_output", "MOPS::Apply_Attributes::1.0": "MOPS::Apply_Attributes::1.0", "gamedev::sop_straighten": "gamedev::sop_straighten", "lattice": "lattice", "matchsize": "matchsize", "vdbdiagnostics": "vdbdiagnostics", "testgeometry_pighead": "testgeometry_pighead", "knife": "knife", "triangulate2d::2.0": "triangulate2d::2.0", "convertline": "convertline", "visualize": "visualize", "guidemask": "guidemask", "vellumpack": "vellumpack", "gamedev::sop_autouv": "gamedev::sop_autouv", "heightfield_distort": "heightfield_distort", "uvpelt": "uvpelt", "timewarp": "timewarp", "shrinkwrap": "shrinkwrap", "assemble": "assemble", "heightfield_maskbyconcavity": "heightfield_maskbyconcavity", "paste": "paste", "volumemix": "volumemix", "delete_overlapping_polygons": "delete_overlapping_polygons", "testgeometry_tommy": "testgeometry_tommy", "planarpatch": "planarpatch", "testgeometry_rubbertoy": "testgeometry_rubbertoy", "solidify": "solidify", "convertheightfield": "convertheightfield", "gamedev::sop_retime": "gamedev::sop_retime", "rishader": "rishader", "uvquickshade": "uvquickshade", "MOPS::Preview_Falloff::1.1": "MOPS::Preview_Falloff::1.1", "MOPS::Preview_Falloff::1.0": "MOPS::Preview_Falloff::1.0", "alembic": "alembic", "gamedev::sop_flowmap_to_color": "gamedev::sop_flowmap_to_color", "primitive": "primitive", "polyframe": "polyframe", "bound": "bound", "softpeak": "softpeak", "gamedev::sop_uv_stack": "gamedev::sop_uv_stack", "volumerasterizeparticles": "volumerasterizeparticles", "musclecapture": "musclecapture", "heightfield_maskbyobject": "heightfield_maskbyobject", "gamedev::sop_flowmap::2.0": "gamedev::sop_flowmap::2.0", "attribcast": "attribcast", "agentclip::2.0": "agentclip::2.0", "matchaxis": "matchaxis", "subdivide": "subdivide", "heightfield_distortbylayer": "heightfield_distortbylayer", "vellumdrape": "vellumdrape", "attribswap": "attribswap", "gamedev::sop_osm_import": "gamedev::sop_osm_import", "volumeresize": "volumeresize", "spring": "spring", "uvtransform::2.0": "uvtransform::2.0", "volumeconvolve3": "volumeconvolve3", "vdbvectormerge": "vdbvectormerge", "volumeramp": "volumeramp", "Sop/rbdmaterialfracture::rbdrewireconstraints": "Sop/rbdmaterialfracture::rbdrewireconstraints", "attribdelete": "attribdelete", "volumesdf": "volumesdf", "particlefluidmask": "particlefluidmask", "vdbprojectnondivergent": "vdbprojectnondivergent", "volume": "volume", "solidembed::2.0": "solidembed::2.0", "heightfield_clip": "heightfield_clip", "hairclumpcore": "hairclumpcore", "line": "line", "haircardgen": "haircardgen", "tetrasurface": "tetrasurface", "dissolve::2.0": "dissolve::2.0", "gamedev::niagara_rbd_split": "gamedev::niagara_rbd_split", "gluecluster": "gluecluster", "vortexforceattribs": "vortexforceattribs", "MOPS::move_along_spline::1.1": "MOPS::move_along_spline::1.1", "MOPS::move_along_spline::1.0": "MOPS::move_along_spline::1.0", "MOPS::move_along_spline::1.3": "MOPS::move_along_spline::1.3", "vdbsegmentbyconnectivity": "vdbsegmentbyconnectivity", "triangulate2d": "triangulate2d", "rbdunpack": "rbdunpack", "gamedev::sop_osm_buildings": "gamedev::sop_osm_buildings", "delete": "delete", "trim": "trim", "sort": "sort", "paintfogvolume": "paintfogvolume", "gamedev::sop_color_gradient": "gamedev::sop_color_gradient", "shapediff": "shapediff", "sblend": "sblend", "twist": "twist", "mountain::2.0": "mountain::2.0", "uvbrush": "uvbrush", "rbdconstraintproperties": "rbdconstraintproperties", "file": "file", "gamedev::sop_group_expand": "gamedev::sop_group_expand", "agentlookat": "agentlookat", "attribcomposite": "attribcomposite", "MOPS::Combine_Falloffs::1.0": "MOPS::Combine_Falloffs::1.0", "grouprename": "grouprename", "strokecache": "strokecache", "posespaceeditconfigure": "posespaceeditconfigure", "capturelayerpaint": "capturelayerpaint", "gamedev::sop_decal_projector": "gamedev::sop_decal_projector", "volumerasterizecurve": "volumerasterizecurve", "oceansource::2.0": "oceansource::2.0", "pointwrangle": "pointwrangle", "spraypaint": "spraypaint", "solidfracture": "solidfracture", "timeblend::2.0": "timeblend::2.0", "guideprocesscore": "guideprocesscore", "dopnet": "dopnet", "shrinkwrap::2.0": "shrinkwrap::2.0", "packpoints": "packpoints", "peak": "peak", "polyextrude": "polyextrude", "vellumunpack": "vellumunpack", "hairgen::2.0": "hairgen::2.0", "stitch": "stitch", "MOPS::Transform_Modifier::1.0": "MOPS::Transform_Modifier::1.0", "rop_alembic": "rop_alembic", "volumetrail": "volumetrail", "gamedev::sop_voxelmesh": "gamedev::sop_voxelmesh", "curve": "curve", "crease": "crease", "wiretransfershape": "wiretransfershape", "volumeslice": "volumeslice", "volumewrangle": "volumewrangle", "softxform": "softxform", "tissuesolver": "tissuesolver", "tube": "tube", "tridivide": "tridivide" }
Edited by Neonzone - Feb. 14, 2019 04:53:13
- Len
- 132 posts
For anyone that runs Houdini on Mac and gets similarly frustrated by lack of a console that can always stay on top for printf's and the like, there IS a solution.
Download iTerm2 [iterm2.com], then set up an Alias inside your /Users/username/.zshrc (aka ~/.zshrc) file like so:
alias houdini="/Applications/Houdini/Houdini20.0.506/Frameworks/Houdini.framework/Resources/bin/houdini"
Or whatever version you're running at the time.
Then follow these instructions I found:
You MUST use the hotkey you set in that last step to open the terminal since it will make sure to keep the window on top.
Then type "houdini" and you should be launching whatever version you run (I'm on Indie). It should stay on top and receive all the console data from Houdini.
One such feature with iTerm2 is the ability to configure a Hotkey Window setting on various iTerm2 profiles. iTerm2 -> Preferences -> Profile -> Keys tab -> Configure Hotkey Window button. Then set a hotkey to launch your Profile and make sure 'Pin hotkey window (stays open on loss of keyboard focus) is checked as well as 'Floating window'.
When you hit the hotkey it will launch iTerm2 and it will stay on top.
- travisrogers
- 13 posts
Trying to get this set up on my MacBook and I keep getting this error in the terminal when launching Houdini 20.0.653:
UNSUPPORTED (log once): POSSIBLE ISSUE: unit 1 GLD_TEXTURE_INDEX_2D is unloadable and bound to sampler type (Float) - using zero texture because texture unloadable
Also followed Len's instructions and installed iTerm. Houdini launches via iTerm and Terminal without issue even with that error, but there seems to be no 'console' connection to the in either case. When I try to run printf in an attribute wrangle I get nothing. However Houdini just crashed and the crash message did show in the terminal. Can't figure out what I'm missing to get this set up. Any help would be appreciated. Running Sonoma 14.5.
