Remove empty attributes
   971   7   0
In Houdini, check all the attributes of the current node, points, vertices, faces, and details. No matter whether the attribute type is integer, floating point, vector, string, quaternion, as long as the attribute value is empty, delete the empty attribute. How to do it? How to write it in vex?
What do you mean by an attribute being empty?
All attributes have some default value. For example, for int type it will be zero, but zero is not an empty value. The only thing that fits the definition of an empty attribute is a string.
Edited by alexwheezy - June 22, 2024 03:15:44
If you want to remove attributes there is the Attribute Delete node or if in a vex context you can use one of the removeattrib function or one of its variations - https://www.sidefx.com/docs/houdini/vex/functions/removeattrib.html [www.sidefx.com]
alexwheezy
On top of this, the default value is user defined
Like if int attrib like i@id has default value -1 would you consider it empty if all elements are at -1 ? Or still 0
And likewise if a string attribute has default value other than empty string, would you consider that attribute empty if all elements are at that default value or rigidly stick to an empty string which is technically a non-dedault value in such case and technically makes it not "empty"
Edited by tamte - June 22, 2024 10:02:38
tamte
Thanks, I forgot that Attribute Wrangle binds the attribute with a default value of -1 if no other value is specified while Attribute Create starts with 0 and the user needs to explicitly set -1 to match the Attribute Wrangle behavior.
Cant chack right now, but I believe Wrangle sets some defaults and type automatically based on common attribute names like @id, @orient, @Cd
However most numerical attribs will still default to 0
What I meant by user having control over default value is that you always can set it explicitly whether in Attrib Create or in wrangle as long as that wrangle is a creator of that attribute, like this:
int @id = 123;
But ultimately I just wanted to point out varying default values so that OP can decide what is considered "empty" for their case
This is just an example. Sometimes when you import something, there will be many such attributes, but the attribute values ​​are empty.
Yes, that is an empty string attribute called name.
You can delete it in the way I mentioned before.
