PDGD_GlobalDataLayerInstance.C not found
   2381   1   1
Hi, I created a simple project to try out the HAPI library.
This is the code:
#include <iostream>
#include <HAPI/HAPI.h>
#include <HAPI/HAPI_Common.h>
void CheckHAPIError(HAPI_Result result, const HAPI_Session& session) {
    if (result != HAPI_RESULT_SUCCESS) {
        int bufferLength;
        HAPI_GetStatusStringBufLength(&session, HAPI_STATUS_CALL_RESULT, HAPI_STATUSVERBOSITY_ERRORS, &bufferLength);
        char* statusString = new char[bufferLength];
        HAPI_GetStatusString(&session, HAPI_STATUS_CALL_RESULT, statusString, bufferLength);
        std::cerr << "HAPI error: " << statusString << std::endl;
        delete[] statusString;
        exit(1);
int main()
    std::cout << "Initializing Houdini Engine session..." << std::endl;
    HAPI_Session session;
    HAPI_CookOptions cookOptions = HAPI_CookOptions_Create();
    HAPI_Result result;
    result = HAPI_CreateInProcessSession(&session);
    std::cout << "HAPI_CreateInProcessSession result: " << result << std::endl;
    CheckHAPIError(result, session);
    result = HAPI_Initialize(&session, &cookOptions, true, -1, nullptr, nullptr, nullptr, nullptr, nullptr);
    std::cout << "HAPI_Initialize result: " << result << std::endl;
    std::cout << "Cleaning up Houdini Engine session..." << std::endl;
    result = HAPI_Cleanup(&session);
    std::cout << "HAPI_Cleanup result: " << result << std::endl;
    std::cout << "Finished successfully." << std::endl;
    return 0;
This builds without an issue.
When the program is ran, this is its output:
HAPI_CreateInProcessSession result: 0
HAPI_Initialize result: 0
HAPI_Cleanup result: 0
Then this exception happens (See attachment).
The exception is thrown from libPDGD.dll.
Have I forgot to do clean up something in my code snippet?
Screenshot (13).png (287.1 KB)
What I was missing were the calls HAPI_Shutdown and HAPI_CloseSession. The code works without calling the HAPI_CloseSession as well. I am not sure why though.
Full code:
#include <iostream>
        int bufferLength;
        exit(1);
int main()
    HAPI_Result result;
    std::cout << "Session handle: " << session.id << std::endl;
    result = HAPI_Initialize(&session, &cookOptions, false, -1, nullptr, nullptr, nullptr, nullptr, nullptr);
    std::cout << "Shut down HAPI session..." << std::endl;
    result = HAPI_Shutdown(&session);
    std::cout << "HAPI_Shutdown result: " << result << std::endl;
    std::cout << "Closing session..." << std::endl;
    result = HAPI_CloseSession(&session);
    std::cout << "HAPI_CloseSession result: " << result << std::endl;
    return 0;
It is easy to miss. The description from function documentation explains the rationale behind this:
/// @brief  When using an in-process session, this method **must** be called in
///         order for the host process to shutdown cleanly. This method should
///         be called before ::HAPI_CloseSession().
///         @note This method should only be called before exiting the program,
///         because HAPI can no longer be used by the process once this method
///         has been called.
/// @ingroup Sessions
/// @param[in]      session
///                 The session of Houdini you are interacting with.
///                 See @ref HAPI_Sessions for more on sessions.
///                 Pass NULL to just use the default in-process session.
///                 <!-- default NULL -->
HAPI_DECL HAPI_Shutdown( const HAPI_Session * session );
/// @brief  Closes a session. If the session has been established using
///         RPC, then the RPC connection is closed.
///                The HAPI_Session to close. After this call, this
///                session is invalid and passing it to HAPI calls other
///                than ::HAPI_IsSessionValid() may result in undefined
///                behavior.
HAPI_DECL HAPI_CloseSession( const HAPI_Session * session );
Edited by Drobek - July 4, 2024 01:35:11
