Hi, I'm trying to write usd via ROP USD Output Node. The problem is when there is an
error during archive generation. It sends no info to console, the real cause
of node cooking failure can only be observed when i click on red dot on this node and watch logs.
Is there any builtin option to write log to console stdout on workitem cooking?
work item logs to console
606 3 1- vania.zuickov
- 3 posts
- alexwheezy
- 293 posts
In the documentation on environment variables, you can find several variables that are responsible for the desired level of logging during cooking. For example, HOUDINI_PDG_NODE_DEBUG, HOUDINI_PDG_WORK_ITEM_DEBUG, HOUDINI_PDG_SCHEDULER_DEBUG, etc.
https://www.sidefx.com/docs/houdini/ref/env.html [www.sidefx.com]
- vania.zuickov
- 3 posts
- alexwheezy
- 293 posts
