Not exactly learning material but I guess moderators will correct me or delete/move the post if see unfit.
I'm VFX environment artist with 20+ years of experience, I always wanted to learn Houdini and if my request is fulfilled it may finally be the right time, my current workflow learning new software involves local LLMs with RAG embeddings of its documentation (currently learning Unreal this way). So, my request is about Houdini's documentation in a **single file** .txt, pdf, whatever available (or if SideFX are kind enough to provide a download link to single file doc).
This LLM RAG learning workflow is super powerful and if you haven't tried it, I recommend it for all sort of data consumption.
Request: Local Houdini Documentation For LLM RAG
2578 1 2-
- Vladimir Dobrev
- edward
- 8081 posts
If you really have a request, you need to do it via the Support menu above under "Report a Bug/RFE". Having said that, maybe you can just a crawler to do that? A quick google shows something like this: https://www.firecrawl.dev [www.firecrawl.dev]
