Nice to see the clones output all AOV to the render gallery, now it's of possible to have a visual framebuffer that's independent of viewports, locked to a specific camera, has a fixed lop node path and has the correct fixed resolution. (Like any other renderer has since the mid 90ies but that's another discussion )
The clones won't output to the render gallery unless a LOP network/node is set in the render gallery's path (green circled bit). I understand the need for that for normal non-clone renders, but the clones have their own LOP network path etc so it can/should always be available in the render gallery independent of the render gallery path. Is there any reason they are not or is it simply an RFE-able oversight?
Force view clone outputs in Render Gallery
585 3 3- Jonathan de Blok
- 274 posts
- robp_sidefx
- 496 posts
Jonathan de Blok
This is the crux of it. The clones have their own LOP network path which means each clone is linked to a lopnet and, by extension, that lopnet's Render Gallery database. We maintain unique on-disk databases per-lopnet and, while the Clone Control Panel is able to provide a holistic overview of all the clones that have been spawned, the *output* from each clone goes to a specific database (i.e., the database for the lopnet that the clone is associated with).
- Jonathan de Blok
- 274 posts
That makes sense from a technical perspective but from a user perspective the renders simply don't show up. Maybe the render gallery can have a 'all databases from this hipfile' checkbox or something like that? or use multiple paths/wildcards?
(Workflow wise it could be a bit less rough when exclusively using clones for rendering and using multiple LOP networks)
More code, less clicks.
- robp_sidefx
- 496 posts
