Hello, I'm pretty much brand new to COP's giving it a try for my compositing.
And I just can't figure out how to cache my entire timeline / video, so I can live playback my composition by pressing play?
I read about it in the documentation, but I just can't find any meaningful info on it.
If anyone knows how to do this, please let me know.
Thank you very much for your time and help, I really appreciate it.
PS. Dear Houdini Team, this is super unintuitive! You should be caching my timeline in the background by default, so I can press play and actually see my composited video.
COP's / Copernicus - caching for live playback!?
1381 13 2- Yannik
- 22 posts
- 8020 posts
- Yannik
- 22 posts
jsmackNo hitting the play button will either play at like 3fps or skip frames dependent on the selected realtime playback mode.
I'm not sure what you mean, does hitting the play button not work for live playback?
As it needs to read multiple .exr files and run various filters for each frame.
I need it to somehow process all the frames, store the processed information, and then play it back to me in live time.
- 8020 posts
- Yannik
- 22 posts
jsmackI don't want to render everything out to disk and have to read it back somewhere just to see what I did in a fluent video, make a change, and then repeat.
oh, you want to render it out. Use the rop image output node to write an image sequence.
I want to be able to just live playback the animation in the viewport by pressing play.
As it stands, the playback performance is not sufficient to play every frame at real time, so I want Houdini to cache the playback.
I can do it with MPlay, I can do it for simulations, I just can't figure out how to do it in COP's.
Node info as well as cache manager both show details for cooking cop networks, I just can't get it to work or figure out the workflow.
- 8020 posts
YannikjsmackI don't want to render everything out to disk and have to read it back somewhere just to see what I did in a fluent video, make a change, and then repeat.
I don't think there is any cache mechanism for cops, the idea is you make a network fast enough that it doesn't need one. The Old cops had caching and was hard coded to assume it is working with sequences. The new cops is just sops, but for images, so caching works the same as in SOPs-only the current frame is cached. I think you can still render to mplay rather than to disk from the rop image output node. If viewing the cop network in the scene viewer, the flipbook tool will work.
- louisx
- 46 posts
If copernicus should be considered for compositing tasks it needs some sort of caching..linke dops have.
With the current speed of loading exrs it can never be realtime without caching. Simple loading of productions exr's (sequences) is soo extrem slow right now its unuseable.
Edited by louisx - July 26, 2024 01:24:34
- raincole
- 539 posts
- 8020 posts
louisx
Well, it should not be considered for that, the devs have stated that is not the goal for this release.
raincolejsmack
The idea is sipmly bad. Copernicus is very slow. None of the cool things they showed in demo can be realistically cooked in realtime on a consumer level PC.
I don't know about you but I've had plenty of setups that run at over 100fps, and at 30 fps at 4k.
- johnmather
- 517 posts
- Yannik
- 22 posts
johnmatherThanks for the heads up. I really appreciate it.
If you're reading .exr files, there is a known issue that causes this to be very slow. We're looking into it. In the mean time, you may be able to get a significant performance boost if you can use a different file format.
I'm personally only familiar with .exr based workflows using the various denoised .exr outputs RenderMan delivers for compositing. As read back times with .exr files are never great and can hardly be done live for complex composites,
it would be a bare minimum to see some sort of cache features - which at least cache files we are reading from disk.
- Ivan L
- 199 posts
+1 I'm surprised with that answer (the idea is you make a network fast enough that it doesn't need one)
It's pretty slow on my PC as well and I have it on the higher end.
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
- Yannik
- 22 posts
This should have been one of the first things they added!
It just isn't a viable approach to try and read back files from disk without caching.
No matter how well optimized the code is, if the disk speed cant keep up with the file size - The playback will inevitably stutter.
There is a lot of merit in making it fast enough to be able to look dev interactively.
If I can add things like glow to my progressive renderview, I will be able to see and work with what I really get as final output. Which is a massive time saver and huge advantage.
So I sincerely hope that they get this sorted out soon so I can actually also comp animations properly.
Edited by Yannik - July 27, 2024 18:10:39
- 8753 posts
Its been specifically pointed out and reiterated many times that the first iteration of new COPs is not yet aiming for compositing even though it definitely can be used for simple ones
All the official examples were mostly for texture generation and some post filters, not any serious comp work or even realtime playback
So I personally wouldnt hold it against SideFX that they decided to squeeze the COPs into the release in the current iteration rather than holding off for it to have all the features that everyone is used to from all the softwares that it has potential to replace
I believe they are fully aware of missing features regarding future compositing focus and will continue to implement them, of course RFEs never hurt just to be sure they are aware of your particular needs
Since talking about compositing there is many more features missing beyond caching, so no wonder its not been advertised as a compositing network yet and will require some patience (like time manipulation, intuitive display/data window handling, multi layer wires, roto, tracking, etc... Or even still some for texture manipulation like UDIM workflows, which may also depend on some multilayer tech etc...)
