Hey
Trying to import UDIMS into Copernicus to rasterize is this not possible?
Copernicus importing/ rasterize UDIMS
1240 5 2- Toketronic
- 40 posts
- anon_user_86835697
- 42 posts
- Toketronic
- 40 posts
- Pendar
- 4 posts
- BabaJ
- 2137 posts
- Pendar
- 4 posts
Have you used UDIMs in the new COPS?
as far as I know there is nothing built in within COPS to see the whole model with its different UDIM textures all in COPS with a preview material node.
This will not work to be able to preview the entirety of the model with UDIMs. You will only be able to see the mesh with UDIMs on the first UV space grid, so UDIM 1.001 or whatever.
I have seen work arounds like the tutorial from 'Inside the Mind' on youtube, which runs the UDIMs through copernicus, then using ROP image outputs to send the textures to 'Stage' however this still only allows you to see the whole model in Solaris after inputting the materials there. Not only that, but the `op:` workflow for textures from COPS to Solaris wouldn't work in this example either.
I would really love a proper UDIM workflow in COPS. I use UDIMs for almost all my important models, also Character Creator 4 uses UDIMS. Cheers!
