Vector3 parameters (Integer or Float) are also automatically identified and displayed using Unreal's XYZ coordinates, but other parameter types won't. This means that a single "Y Position" parameter exposed in Houdini will actually control the Z position in Unreal's coordinate system. You may choose to prevent a Vector3 parameter from automatically switching its Y and Z axis when displayed in Unreal by setting the hengine_noswap tag to 1 on the parameter.
hengine_noswap Float (tuple3) Indicates that the Vector3 Y and Z values should not be swapped in Unreal.
how can unable houdini engine to auto swap axis. i found information how to do it but no work for me. if someone have information to how control the hengine_noswap to get the HDA exact like in houdino without swaping y for z. please help
houdini engine Unreal (hengine_noswap) option
1436 2 0- ANGELGHOSTCORE
- dpernuit
- 545 posts
In the type properties dialog, select the Vector3 parameter you want to enable noswap for.
At the bottom right, you'll find tags.
Click on the + button to create a new tag, name it hengine_noswap, and set its value to 1.
Apply the changes, save the hda.
In unreal, changing the Y value of the parameter will also change the Y value in H, same for the Z value.
- JoseBringas93
- 15 posts
